Author Topic: New Swing Mill Setup  (Read 217 times)
Offline Lyndaker
« on: September 13, 2020, 02:37:00 PM »
So I just put down money for a new DL swing mill. I have never owned a mill before. Call me Rookie!
I'd like to see pictures of your swing mill dogging setup. I'm very handy and pretty sure I can save some bucks by making my own dogging. Also did you buy factory rails or make your own. Rail extensions are pricy and I'm pretty sure it would be a simple thing to purchase 20 lengths of steel of the correct shape and diameter and build your own adjustable feet with threaded rod or bolts. Any pictures and descriptions of your setup would be most helpful.
Thanks in advance for helping out this rookie.
Offline quadracutter222
  • D&L 10/20, Kubota XD23, Long 5n1, MS461
Re: New Swing Mill Setup
« Reply #1 on: September 13, 2020, 08:43:53 PM »
That is awesome! Congrats ;)  We have a 10/20 and really like it.  What model did you go for?
Ours was purchased used and came with 3 sets of the dogs. I really like them, but if I was to do my own thing I would do something along these lines:
Efficient Sawmilling Tips & Tricks - Peterson Portable Sawmills
down under the 'Holding Logs in Place section'
or something along these lines
He's back at it again - Milling Dimensional lumber from Redwood logs with a Turbo Sawmill! - YouTube
or
Setting your work area up correctly.
Depending on how you load your logs (live or dead deck) you are going to need something to bridge the gap between your deck and dogs, over the rail, so as to not roll logs on your rails.  I think there are some good vids on the D&L Facebook page that show this.  If you are going to machine load one at a time, then no factor.
I believe the standard set up comes with enough rail to cut 21', but I imagine you can choose to not buy them.  If you were going to fab your own, matching the V rail size should be easy, same as making adjustable feet.  The trick would be joining factory rails to homemade, as the factory has an internal triangle extrusion, that a chunk of triangle rail interfaces with to make a strong join.
I am happy to take pics/field questions if you have them.
Does any one here use a Swing Blade setup to cut Cross ties?
Started by just_sawing on Sawmills and Milling
Last post December 31, 2015, 08:02:16 PM
by Ianab
Slick mill setup......
Started by hardtailjohn on Sawmills and Milling
Last post March 25, 2014, 04:11:01 PM
by Wellmud
Question on M14 mill setup
Started by tmroper on Sawmills and Milling
Last post September 11, 2009, 06:16:54 PM
by Ron R.
automatic mill setup
Started by Bert on Sawmills and Milling
Last post March 04, 2011, 12:09:34 PM
by Jeff
