Dynamic Green Products Inc.
Author Topic: Hydro Ax 670 Cutting Head not working  (Read 517 times)
Offline kiko
Re: Hydro Ax 670 Cutting Head not working
« Reply #20 on: September 16, 2020, 01:57:20 PM »
The hydraulic switch is made to return. In normal operation hitting this switch one should reset the pilot. Holding it down is just a built in bypass mode.  You need to check your door switches and the door switch relay
These relays are located behind the right hand door. Door switches are located at the bottom of each door.
Old Hydro-Ax 520 with 8' cutter head
Started by john_bud on Forestry and Logging
Last post December 22, 2007, 02:02:25 PM
by Gary_C
Hydro-ax shear head. where do I buy knives?
Started by Sam Strom on Forestry and Logging
Last post February 28, 2020, 09:12:49 PM
by timbco68
Lt40 head feed/drive not working well
Started by Dan_Shade on Sawmills and Milling
Last post March 07, 2018, 02:26:08 PM
by terrifictimbersllc
question
LT40 Head Drove Down While Cutting
Started by forksdad on Sawmills and Milling
Last post February 16, 2018, 08:19:44 AM
by Sixacresand
