Author Topic: Seals for Woodmizer Blade Tensioner  (Read 199 times)
Offline ronwood
  • Enjoy Making Sawdust !!
« on: September 16, 2020, 02:36:47 PM »
I blew out one of the 1 in seals on the blade tensioner on my 2003 LT40. The seals kit is on backorder with Woodmiizer. Has any one sourced the seals from another supplier.
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Seals for Woodmizer Blade Tensioner
« Reply #1 on: September 16, 2020, 02:48:31 PM »
If you have a nearby hydraulic cylinder rebuilding shop, I would go there.  They probably can match the diameter of the "square" O rings.
Offline Cjross73
  • Work in progress
« Reply #2 on: September 17, 2020, 10:41:20 AM »
I've had to do what MM said a couple times.  My local hardware store had a hydraulic o ring assortment that worked temporarily
LT40, Stihl saw, Old green tractor
woodmizer blade tensioner
Started by Buck on Sawmills and Milling
Last post December 09, 2011, 07:01:35 AM
by Norm
FabTek bar tensioner piston seals
Started by deastman on Forestry and Logging
Last post September 11, 2016, 10:12:39 PM
by North River Energy
Blade tensioner
Started by kenfrommaine on Sawmills and Milling
Last post June 11, 2016, 09:02:50 AM
by york
blade tensioner
Started by Joey Grimes on Sawmills and Milling
Last post June 28, 2015, 10:10:09 PM
by Magicman
