Dynamic Green Products Inc.
Author Topic: 371 372 372xtorque  (Read 208 times)
Offline Firewoodjoe
  • Im getting old
371 372 372xtorque
« on: September 24, 2020, 07:53:50 PM »
Well Iíve got them all. A pile of them. Most just need minor stuff. Coil clutch brake band. Stuff like that. I have one xtorque that Iím sure needs rebuilt. Sucking air hard. Will just rev high then die. I have new in the box saws but Iíd really like to fix all these because itís a bad habit and a waste of money to just keep piling them up. My question is is it worth buying those kit/part saws? Or stick with oem? Then will the clutch assembly and oil pump fit from the xtorque to the older saws? This would make it quicker for me.
Offline steele109
Re: 371 372 372xtorque
« Reply #1 on: September 24, 2020, 09:30:55 PM »
Hi everything on the clutch side will work on 365,371,372. I have several kit saws and they run good but given the choice I would stick with oem. Everything on a xtorqe except the air filter,intake,carb,boot, cylinder and piston will interchange with the original.
