Dynamic Green Products Inc.
Author Topic: Homemade skidder  (Read 12598 times)
Offline tacks Y
Re: Homemade skidder
« Reply #20 on: September 30, 2020, 08:45:38 AM »
I would not be in a hurry to change tires, even w/cracks they would be better than a radial tire. I built one with semi tires did not hold up. Went to back hoe tires which held up great.
Offline Old saw fixer
  • Grumpy old man!
« Reply #21 on: September 30, 2020, 10:33:52 AM »
Please, what is this "Deuce" you speak of?
Stihl 036 Pro, 017, MS261 CM, MSA140 CB
Logrite Cant Hook (with log stand), and Hookaroon
Online ljohnsaw
« Reply #22 on: September 30, 2020, 10:48:57 AM »
 :P
John Sawicky
Online Iwawoodwork
« Reply #23 on: September 30, 2020, 10:53:46 AM »
The Duce is a military 2 1/2 ton 6x6 truck.  usually called a duce and a half.
What a find , really enjoy seeing those home built machines because it gives ideas for a lot of us.
Offline DeerMeadowFarm
« Reply #24 on: September 30, 2020, 10:54:15 AM »
I'm talking about the military "Deuce and a half" 6x6 truck. It's a 2-1/2 ton truck hence the nickname Deuce and a a half.
https://en.wikipedia.org/wiki/M35_series_2%C2%BD-ton_6x6_cargo_truck
Offline armechanic
« Reply #25 on: September 30, 2020, 11:05:45 AM »
This appears to be an old GMC M135 single wheel.  The wheel don't have enough dish to install dualls and without the original auto transm it is real low geared as the transfer case is only for 4X4.  High & low range was built into the transmission  I worked on these in my early mechanic days for Uncle Sam.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
« Reply #26 on: September 30, 2020, 11:18:58 AM »
The transfer case used has Hi/lo as well as 4wd/2wd. I think the transmission itself is not from the Deuce; it has a GM casting number on it that I need to look up.
Offline chevytaHOE5674
« Reply #27 on: September 30, 2020, 11:40:27 AM »
Are the axles Rockwell 2.5tons or GMC 2.5 tons?
« Reply #28 on: September 30, 2020, 01:39:15 PM »
I'm not sure I'd know what the difference is...?
Online mike_belben
  • Pulp Friction
« Reply #29 on: September 30, 2020, 01:45:20 PM »
6 lug budd with square tube and a toploader chunk is rockwell. 6.xx ratio.
A cast iron high-neutral-low gm tcase is likely to be np205 if its all gear .. Thatll have 2 shift forks with 3 position each. Or an np208 if its planetary.  Passenger side drop.
If divorced passenger drop it probably has some ford input parts.
Revelation 3:20
« Reply #30 on: September 30, 2020, 01:52:28 PM »
GMC axles have the same wheel pattern and similar gear ratio, but round tubes and a removable third member like a ford 9". Also a cover that looks like a tic-tac-toe board.
Online mike_belben
  • Pulp Friction
« Reply #31 on: September 30, 2020, 02:07:55 PM »
Thats right.. Theyre like an overgrown eaton HO72 with a ribbed ring gear cover. Forgot about those.  Not too common.
Revelation 3:20
« Reply #32 on: September 30, 2020, 02:48:32 PM »
OK, here are some (not so great quality) pics I ran out and took. First of all, it's not an NP205 or 208 transfer case. This thing is huge and has two rear output shafts and a passenger side drop for the front. My photo of this was way too bad to post so I'll have to try to get another one later.
Here is the winch from the left side:
And again from the right:
It's made from what appears to be the same axles as what is on the machine. Front:
And rear:
I don't know if this helps in identifying the axles used...?
Online mike_belben
  • Pulp Friction
« Reply #33 on: September 30, 2020, 03:28:28 PM »
Revelation 3:20
« Reply #34 on: September 30, 2020, 03:36:33 PM »
Ford AA4000.  Very old.
AA-4000 Rear Axle Parts Group | AAFords-FMAATC
Yah? Are you saying for the winch or for the axles as well? Because I wasn't aware that Model AA trucks came 4WD...? Also, all the photos on the page you linked shows 5 lug nuts where my axles have 6.
Offline Walnut Beast
« Reply #35 on: September 30, 2020, 04:31:01 PM »
G503 1 1/2 ton axles
« Reply #36 on: September 30, 2020, 04:41:45 PM »
  • Grumpy old man!
« Reply #37 on: September 30, 2020, 07:20:06 PM »
Okay, I know what a deuce and a half is/was, I was raised an Army brat. I never heard them referred to as a "deuce".  We weren't allowed to hang around the motor pool, I guess that is why.
« Reply #38 on: September 30, 2020, 07:32:01 PM »
Looks like a GMC 2.5 ton CCKW split axle. Very old, very fragile, and parts are expensive IF you can find them.
« Reply #39 on: September 30, 2020, 08:32:28 PM »
I think there more like 1 1/2 ton Timken 🤔
homemade skidder Pictures Added!!!!!!!!!
Started by timberfaller390 on Forestry and Logging
Last post April 20, 2008, 11:59:19 PM
by twobears
Garrett Skidder model 20 homemade muffler sound
Started by tantoy on Forestry and Logging
Last post October 19, 2016, 06:59:17 AM
by Logger RK
Advice on improving skidder stability ?!? Bought a new to me skidder need tips..
Started by RunningRoot on Forestry and Logging
Last post November 10, 2014, 04:45:59 AM
by Nate379
wireless
Arch skidder vs 3 point skidder
Started by WMcGinn on Forestry and Logging
Last post June 08, 2009, 11:36:08 AM
by Chico
