Dynamic Green Products Inc.
Author Topic: moisture meter  (Read 302 times)
Offline sawwood
moisture meter
« on: October 02, 2020, 05:42:22 PM »
I have seen some wood drying video's and not one tested the wood the same with there meter. Some show testing on the face of the lumber
and some on the side. What is the right way to use the meter ? If on the face do you test near the end or middle of the board. I know that
Gene said the real way to see how dry the lumber is with samples in the microwave till the weight does not change. I also if you use samples
what part of the board do you use for them ?
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline K-Guy
    • http://www.nyle.com/
Re: moisture meter
« Reply #1 on: October 03, 2020, 09:30:02 AM »
With pinless meters you test on top of the board and pin type can be used either way.
For how to do sample boards Nyle has a video on our youtube channel.  There is a link in our blog below.
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline GeneWengert-WoodDoc
Re: moisture meter
« Reply #2 on: October 03, 2020, 09:59:00 AM »
K-Guy is right about pin meters especially if you have insulated needles.
The pin meter under 30% MC can be used to run a kiln rather than weighing samples, but there can be some errors.  I. The kiln, use probes intended for that purpose.  The cost of a reliable meter with auxiliary equipment is around $600.  Get one made in USA so that it is calibrated for USA species and can be repaired.
There is a comparison of three meters that I did and is in the Appendix of DRYING HARDWOOD LUMBER.
Moisture Meter
Started by oldmatelot on Drying and Processing
Last post November 19, 2012, 11:04:36 AM
by lowpolyjoe
What moisture meter do you use?
Started by Robert Owens on Sawmills and Milling
Last post October 22, 2015, 12:17:54 AM
by Brucer
moisture meter
Started by xlogger on Drying and Processing
Last post January 23, 2017, 05:00:13 AM
by xlogger
Which Moisture Meter?
Started by WoodHacker on Sawmills and Milling
Last post October 29, 2010, 09:22:40 AM
by paul case
