Dynamic Green Products Inc.
Author Topic: New Saw reccomendations  (Read 1065 times)
Offline barbender
Re: New Saw reccomendations
« Reply #40 on: October 15, 2020, 12:21:04 AM »
Yep I really like my little 261, it's got a lot of torque for a 50cc saw.
Offline duane4238
  • Member*
« Reply #41 on: October 15, 2020, 08:09:14 PM »
Well, from all the replies I've read here, I don't think anyone has used any of these chainsaws who had an unrepairable rotator cuff.  I went through that, but luckily the Dr. was able to fix my shoulder. Took 2 full years before it felt like it was fully healed. I had an 028 Super but it was just too heavy for my shoulders. I ended up getting an MS192. Quite a powerful little saw with a 14" bar and the lightest I could find.  I've cut lots of wood with it. Now that the shoulders are better, I bought a new MS250 with 18" bar and couldn't be more pleased. The OP is gonna have to go and handle some of these saws before he makes a decision.  It's no fun cutting wood when your shoulders hurt all the way to your toes. Good luck with your choice.
Duane
Offline btulloh
« Reply #42 on: October 15, 2020, 08:18:45 PM »
Good points. Trouble is it sounds like the OP has a 70cc task and a 35cc shoulder.  I understand first hand when once routine tasks donít fit into oneís current capabilities any longer. Makes for some tough realistic choices.  At a certain point it becomes necessary to give up mountain climbing and pole vaulting. The mind still wants to do all that, but . . .
Offline realzed
  • Old Fart
« Reply #43 on: October 15, 2020, 09:01:00 PM »
I can fully relate with the shoulder comments having had both of mine redone and with a few bits of hardware still implanted in them.
I've also got fairly severe osteoarthritis throughout my shoulders, elbows and especially my thumb joints - so not only can I relate to how it feels, but also how it can hurt your hands to try and start saws that are stubborn and 'kick back'.
To do the best I could in trying to get a saw as light as possible and as easy to start that still retained as much power as possible I tried out a few and settled on a Stihl MS 261CM.
It pretty much rules when it comes to power / weight ratio, has a decomp valve, and is about as well balanced and vibration free as there is out there.
I opted for a 20" bar so I wouldn't have to bend too far forward as a shorter bar would require, and for the most part it has served me very well and I couldn't be more impressed with the power and torque for the size, balance, and weight.
Al would be happy - as I added a 461-style Rescue Saw 'D' handle as he often mentions, to make it a lot easier to get and keep a grip when starting it, verses the smallish OEM pull cord handle and it all works quite well for me - on a small saw that still requires a good sharp tug or two to get it rolling!
Unless one really really needs a longer bar than a 20 incher most or all of the time - I would certainly recommend a look at one of these little guys - you might be very happily surprised all things considered!
Offline btulloh
« Reply #44 on: October 15, 2020, 09:15:05 PM »
Those 261ís really are amazing for 50cc saw and the power/weight is outstanding. They will do good job on bigger wood, just takes a little longer. Might just be the sweet spot for shoulder issues. You gotta be able to start a saw before you can run it.
Best of luck to OP.
