Author Topic: Brand new WM LT40 super wide having issues  (Read 1954 times)
Offline Jwswan
  • Forward!
    • jwswanandsons.com
« on: October 13, 2020, 06:05:37 PM »
Hello all;
I'm now on my second Woodmizer, an LT 40 super wide with the 38 hp Kohler.   It's got just shy of 10 hrs on it, and I'm having issues with some really loud squeaking from the main drive pulley/shaft on the back of the engine, and the pulley itself is getting really hot after an 1-2 hrs of running.  It's hot enough to where the belt is smoking  quite a bit, even when it's off. After it completely cools down, it won't do it again until it gets hot.   I checked the belt tension on the alternator, drive belt, and the brake strap.  I then called WM today, got a really helpful tech guy who had me go through them again.  Since it was after hours when I got deduced where the smoking/squeaking was coming from, I called and left a VM.   In the meantime, I figured I'd come to the FF oracle and get ideas/advice.  I love, WM and the new mill, it's a big step up from my LT 35 manual, but I want to make sure it's running right.   Thanks in advance.   -Josh
Keep 'em guessin'.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Brand new WM LT40 super wide having issues
« Reply #1 on: October 13, 2020, 08:00:32 PM »
Check oil level in the main drive bearing!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: October 13, 2020, 08:28:18 PM »
Yes, very important.  There is a clear plastic tube that serves as a sight glass for the main bearing.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline Jwswan
  • Forward!
    • jwswanandsons.com
« Reply #3 on: October 13, 2020, 08:30:01 PM »
Chuck and Yellow Hammer;
Thanks! yep, I checked that and it's showing it full.  Is there also one on the kohler itself? could it be giving me a "false" full?  I sure appreciate the help. -Josh
Keep 'em guessin'.
Offline Southside
    • White Oak Meadows
« Reply #4 on: October 13, 2020, 11:43:42 PM »
Do you have an IR gun you can use to trace back the source of the heat? I would think you would see a difference happening pretty quickly.
Offline Jwswan
  • Forward!
    • jwswanandsons.com
« Reply #5 on: October 14, 2020, 05:40:28 AM »
Southside;
I don't, but that's a good idea.   I'll also see what the folks at WM command central say.   Being it's so new, I don't really want to tear into too much myself.   -Josh
Keep 'em guessin'.
Offline randy d
« Reply #6 on: October 14, 2020, 06:39:23 AM »
Josh did you try giving Steve down in Mosinee a call he did a great job of helping me out when I had a problem with my mill. Randy
Offline 47sawdust
« Reply #7 on: October 14, 2020, 06:41:54 AM »
I would be on the phone to WM immediately.
Mick
Offline customsawyer
    • The Custom Sawyer
« Reply #8 on: October 14, 2020, 06:54:15 AM »
Check if the engine is a little to far forward or back. Belt might be rubbing on the pulley. Look for wear on one side of the belt or the other. Check for wear on the drive pulley.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline Jwswan
  • Forward!
    • jwswanandsons.com
« Reply #9 on: October 14, 2020, 07:20:26 AM »
Randy;
Yep, I'm gonna call Steve this morning.    He's been super to work with when I've picked up both mills.    CustomSawyer, you might be right.  I didn't see any big wear on the belts, but I'm also not sure how much wear is too much.  This seems like it is definitely a job for a pro to evaluate.    Thanks again for all the input. -Josh
Keep 'em guessin'.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #10 on: October 15, 2020, 07:27:00 AM »
What customsawyer said pulleys not lined up.
I don't think they build a mill then try it out on a log before it gets sent out anymore like they did years before.
Good luck
Offline Klicker
    • www.freespiritfarm.ca
« Reply #11 on: October 15, 2020, 12:05:10 PM »
The good thing about living on the east coast is the the west coast is still open for a couple of hours latter if you have a problem. The phone numbers for all the dealers is in the Woodmizer Way
2006 LT 40 HD
Offline alan gage
« Reply #12 on: October 15, 2020, 12:09:37 PM »
Spray/pour some water on the belt. If the noise changes/goes away the noise is coming from the belt. If it's a bearing problem the water will have no effect.
Alan
Offline Bandmill Bandit
« Reply #13 on: December 09, 2020, 02:26:34 PM »
The problem is likely the belt it self. I have posted quite a bit re Woodmizer alternator problems. The most significant is what I believe to be manufacturing over site that it seems has yet to be corrected.
The "factory" belt is your standard Hardware store variety that is designed for a lawn mower or furnace etc and other small HP applications referred to as a nominal HP belt applications. These belts are not even the correct profile for the standard Delco CS135 alternator pulley, hence the short life and serious over heating issues.
The belt you want is your mills version/length of the NAPA PREMIUM XL series (or equivalent) in the correct length ASSUMING you have a V groove drive. These are not cheap belts and the go about 1200 to 1500 hours before I change em out. In reality at 1200 they shoulda been changed about 200 hours ago but they go the distance and they don't run hot. Dont have to run em so fiddle string tight either.
This one is for LT40 HD28G mill.
Online donbj
« Reply #14 on: December 09, 2020, 02:40:28 PM »
It would be interesting to hear how this turned out. Could be helpful to others.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
« Reply #15 on: December 09, 2020, 03:16:47 PM »
I did my first post on this about 12 years ago when I had the same issue. It is what motivated me to research the alternator replacement issues that seemed way too common.
Hence my extensive knowledge and expertise on the subject of alternators on wood mizer that use the CS135 Delco alternators.
Heres a link to one of my earlier posts;
https://forestryforum.com/board/index.php?topic=35868.msg975610#msg975610
Online mike_belben
  • Pulp Friction
« Reply #16 on: December 09, 2020, 03:32:00 PM »
Im gonna shoot from the hip and say its too much HP for the belt in its present layout.  Could be profile, tension, belt angle, condition etc.  But 38hp is a good bit for 2 uncogged belts.
Sheave alignment needs to be spot on.  They could be trying to climb a shoulder.
Psalm 37:16
« Reply #17 on: December 09, 2020, 03:52:51 PM »
Thats not a shot from the hip belben. Pretty much nailed it. BUT the problem is likely 99% incorrect belt for application. That alternator requires 5 to 7HP to turn it under full load so you need a belt that will pull 10 to 12 HP. That is NOT a furnace fan belt.
Everything else mention can be a contributing factor BUT a new mill should NOT have those issues yet. IF this was a first for Woodmizer then it could be a puzzle BUT I know that all the people I have helped with thi issue, put on a proper belt and the BELT issues disappear.
I HIGHLY recommend reducing alternator's driven pulley by at least a 1/4" as well. Drops the operating temp about 60 +. I reduced my pulley by 3/8".
HEAT in alternator operation is the single most critical factor in alternator life span. You want them running under 200 and preferably around 160 on a hot hard working day.
Mine was running at 300 and higher as delivered from factory. Just putting the right belt on dropped it to 240/250 ish which is still too hot. Reducing the pulley size by 3/8ths dropped temp to 190/200 which the high end of acceptable. The added heat sinks took me to 160/180 range. Prefect range for long life and max output on demand.
Offline jeepcj779
  • "Watch this" - Famous last words
« Reply #18 on: December 09, 2020, 08:00:27 PM »
Is this an issue that is isolated to the gas motors, or is it an issue with the diesel motors as well? Seems like a better belt would be a pretty simple and low cost upgrade for the factory to do. Same goes for pulley size. I have to think at this point that these machines have been engineered to do what the factory needs them to do, and that the pulleys and belts would all be correctly sized for the application. I have to wonder why that may not be the case. Would be nice to hear from Wood-Mizer on the subject.
Offline stavebuyer
« Reply #19 on: December 10, 2020, 03:25:11 AM »
Alternators were a consumable item on my LT70DCS 55HP Yanmar.
up/down issues with 2001 WM lt40 super
Started by flatrock58 on Sawmills and Milling
Last post August 22, 2014, 10:16:49 PM
by flatrock58
LT40 Super Wide Diesel
Started by Sixacresand on Sawmills and Milling
Last post December 27, 2018, 09:11:30 PM
by thecfarm
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
lt40 super, Super expensive part! lol
Started by geraldhale on Sawmills and Milling
Last post January 31, 2020, 03:48:18 PM
by Bandmill Bandit
