BLUECREEPER Poster Award #4!
The pine will shrink a little less. Smaller gaps.
After a year there will be a lot of dirt in the wood and be hard on planer blades. Using what you saw is always the goal, but I'd consider selling and putting plywood down. Add hardwood later after it's dried if you'd like
I like Ruffgear’s approach. Put down a subfloor of whatever you have pine or oak. Use the subfloor until you have enough oak dried. Then machine the oak to be straight and square prior to installing.
I don't know about you, but after a year my shop would be packed wall to wall with "stuff". Are you prepared to empty the shop in a year to redo the floors? Planning now may save alot of extra work later.
Planing green is nearly impossible, you'll need to give it a bit of drying time or it just won't feed. I'll do it for a miscut or two, push/pull and cuss but usually even there I'll stand them up in the breeze for a few days.
Did you use green SYP for your framing? i just framed a 10x9 "outhouse" with 2x4 poplar right off the mill. I have some SYP I could use, but was worried about the sap if using green. What was your (and other's) experience like with SYP?btw, I used 2x8 floor joists at 20" OC and put 5/4 thick poplar boards down on top of that for the floor. 3 three inch screws over each joist. I did use a router to cut in a 3/8 deep shiplap to compensate for any shrinking. Some of my boards are 18 inches wide, so I may still end up with a gap!thanks,forrest
Started by fred in montana on Timber Framing/Log construction
Started by Jim_Rogers on Timber Framing/Log construction
Started by Phorester on General Woodworking
