Dynamic Green Products Inc.
Author Topic: Bar goes part way into tre and no farther  (Read 754 times)
Offline Ba_50
« on: October 24, 2020, 09:00:17 PM »
I have a husky 440e and 18" poulon saw.
When either bar gets mostly into a tree, it won't go any deeper. See sawing helps a little but not much.The depth gauges are ok. What is causing this?
Thanks.
Online thecfarm
Re: Bar goes part way into tre and no farther
« Reply #1 on: October 24, 2020, 09:03:21 PM »
First off, have you tried a new chain?
Kinda sounds like one side of the chain is cutting better than the other. Making it bind up in the cut.
Offline Ba_50
« Reply #2 on: October 24, 2020, 09:32:01 PM »
One is new
Offline lxskllr
  • dummy with saw
« Reply #3 on: October 24, 2020, 09:44:18 PM »
Try sweeping the cut. Let up on the bar, and kind of pull it to you. The idea is to get rid of chips in the kerf. Maybe it's binding.
Offline old guy
« Reply #4 on: October 24, 2020, 10:53:30 PM »
Sounds like there is a burr on the bar which is hanging up in the cut.
Offline Tacotodd
  • To learn and help
« Reply #5 on: October 25, 2020, 02:29:45 AM »
When was the last time you sharpened the chain?
What was your procedure?
Can you show a picture of the chain?
Questions abound!
Trying harder everyday.
Offline mike_belben
  • Pulp Friction
« Reply #6 on: October 25, 2020, 08:37:01 AM »
If the chain is new and bar isnt bent its either than your rail height is uneven or your rails have spread open or both.  Or you have the wrong gauge chain on it.
 The chain is leaning on the rails so that the chain sideplates are no longer parallel to the bar sideplates which steers the kerf off track.  eventually the bar cant make the turn so to speak.  Itll get real hot and refuse to throw chips, just dust.  Usually the nose will cut a little better.  Check how much the chain can rock on the bar side to side.  Dress the rails and close them up if needed.  Keep the oiler and bar groove maintained and free of sawdust.
Revelation 3:20
Online ladylake
« Reply #7 on: October 25, 2020, 12:24:25 PM »
 Is it cutting straight,  maybe a narrow kerf chain on a regular bar.   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline JohnW
« Reply #8 on: October 25, 2020, 12:39:01 PM »
Do you use plastic wedges to keep the tree from setting on your bar?
Offline s219
  • Member*
« Reply #9 on: October 25, 2020, 03:42:34 PM »
Only time I have seen this happen is when the chain or bar is messed up and causes the cut to be curved.  The flat of the bar will only go so far into the curve before it binds (can't move a flat object through a curved cut).
Offline Mountain_d
« Reply #10 on: November 11, 2020, 07:40:45 AM »
I would say your bar is bent. Even a small bend will mess you up. Take the bar off and lay it on a level surface. Press down on various spots. Any wobble and you have a bend.
Mountain
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Offline John Mc
« Reply #11 on: November 11, 2020, 07:58:48 PM »
As others have already noted: it's most likely an unevenly sharpened chain and/or bar rails worn unevenly. Either one will cause the saw to cut on a curve. It my cut fine when the bar is only partway into the kerf. However, as you go deeper, and especialy as the chain on the back side of the bar enters the kerf, it will bind up.
Basically you are forcing the straight bar into a curved cut. It's kind of like what happens when you try to cut too tight of a radius with a jigsaw: it binds up.
Part intro, part seeking advice
Started by AllyCat on General Board
Last post December 27, 2016, 08:23:09 PM
by WV Sawmiller
Ladies and Gents-- Tie on Yer Bibs--Part 2--Part 3
Started by Fla._Deadheader on Sawmills and Milling
Last post April 09, 2006, 11:20:10 AM
by sawguy21
Part Circle Mill Part Band Mill???
Started by ahiggins1 on Sawmills and Milling
Last post December 21, 2009, 06:45:45 PM
by old joe
Help ID-ing a Part
Started by FayettesFinest on Chainsaws
Last post January 20, 2015, 08:35:49 PM
by JB Griffin
