We have contest winners!
Some place you don't have to lug wood a long ways over clean floors.
Maybe I'm missing something. The apartment seems to have everything but a bedroom?
The garage door will be put in once we build the house.
I cannot read the elevations such as wall heights as my zoom doesn't get me there. The top of a flue, as I recall, (my minds getting a tad oldish) should be x # feet higher than any roof surface within 10' , something like that. What type of ceilings or roof does it penetrate? In my cabin build the flue will use whats called a "roof support" such as cathedral ceilings and "A"-frames use. Single wall stove pipe meets that sheet metal box then mates with multi-wall pipes, through the proper boot for the roofing and pitch, etc., then on up to where it will both draw and not backdraft either. Also a brace setup and a cap. As a guy that has burned a whole bunch of wood I can say that the best of them will come back at you on days when the barometer is playing jokes on yer flue. Is in the garage 1st, then modify the flue and move it later a thought worth having? Have you considered the outside burners I mentioned? Never seen this but I suppose some people might have a "sit and see it fire" along with an outside thingy.
Started by Alcranb on Firewood and Wood Heating
Started by Bill Gaiche on Firewood and Wood Heating
Started by Jerryok1971 on Firewood and Wood Heating
Started by york on Firewood and Wood Heating
