We have contest winners!
3' above the highest point within 10' or 2' above the ridge is code, but, that looks like a recipe for a downdraft. Wind rolling off the upper roofs is likely going to shove the smoke back down that pipe.Just to stir the pot, outdoor wood boilers have yet to approach the dim flicker of stone age technology.
Tech wise my recent used stove buy for my cabin build has a catalytic converter in it and represents my first stove with one of those honeycomb thingies. Hard to imagine all that "stuff" going through those little honeycomb holes of about 3/16"SQ? I bought the Vermont Castings stove as a basket case and FWIOW, I came real close to leaving it out when I re-assembled the stove.
Put it central in the living area and near the roof peak, you have to get heat from the stove to all corners of the house. The further the heat has to travel the cooler it becomes. At least 3 feet clearance above the peak. Put the flu straight up, no turns.The old timers knew this a long time ago in those old square farm houses up here. I built a new house 2 years ago, followed all them rules. Flu stays clean as a whistle even though I check every month of wood burning. Just some powdered soot falls in the pale from the brush. I burn any species of wood off the woodlot from my thinnings. I've got 43' to the top of the flu including, basement floor to flu join from stove, and double wall stove pipe from stove into flu. Mine is a furnace.
I agree with the red X location as well. What stove is the next question.
Started by Jerryok1971 on Firewood and Wood Heating
Started by Alcranb on Firewood and Wood Heating
Started by Wedgebanger on Firewood and Wood Heating
Started by york on Firewood and Wood Heating
