We have contest winners!
A lot of that plastic stuff is put together with an rf welding process. Hard to replicate at home. Some people use a low temp soldering iron and strips from a milk jug as a filler. Easy to mess up and melt a hole though. Seems iffy at best for all the time invested.
OK....been down this rabbit hole personally. I was cleaning out my oil tank with compressed air(BAD IDEA) and I heard the tank POP. I split the tank. Soooooo.......cleaned all the original adhesive completely off both halves....chem-ed the seam, then followed with water to wash the chem off and dried completely. I used a commercial epoxy that was gas/oil resistant(many tiers above JB Weld) and clamped the two halves together and let cure a WEEK @room temps. Result was a perfectly sound tank assembly that lasted for six months of hard use and started leaking AGAIN!:( I don't know how Husky did it at the factory....i.e., how they prepped the surfaces and what product they used to bond the halves etc.....but I suggest you don't go down this rabbit hole. It may even have something to do on a molecular level with virgin magnesium......dunno.Then I got paranoid because of the scarcity of 2100/2101 parts and bought tank assemblies that weren't leakers. What I wound up with is a bunch of tank assemblies where the PO's had stripped out threaded holes, gobbed back in JB Weld and re-threaded the holes. So at some point I'll get those messes all cleaned out and the proper threaded steel inserts back in there.I'm not saying you can't fix this issue....just that I couldn't and will not recommend a fix.....six months of hard use and leaking again was a bitter pill to swallow. This wasn't an issue with the original 2100/2101, so there were never a lot of tank assemblies floating around with dealers. This makes the availability of spare tanks even more dicey today.Most likely as these saws aged, throwing them around in the back of pickups made the bond for the tank halves fail. In my long decades of use with the 2100, I don't find it a 'use' issue. Kevin
Quote from: btulloh on November 08, 2020, 09:45:13 PMA lot of that plastic stuff is put together with an rf welding process. Hard to replicate at home. Some people use a low temp soldering iron and strips from a milk jug as a filler. Easy to mess up and melt a hole though. Seems iffy at best for all the time invested. This is not plastic, it's magnesium. Must be some miracle fix out there somewhere
I have welded magnesium/aluminum cases with gas and special rod and flux but it took considerable practice. Many years ago so don't ask me how.
And people making shelf queens of these saws, or only using them occasionally can boast even less.
Started by GRP7099 on Chainsaws
Started by giant splinter on General Board
Started by motohed on Chainsaws
Started by Polly on Firewood and Wood Heating
