Dynamic Green Products Inc.
Author Topic: 066 mag crankcase  (Read 469 times)
Offline 421Altered
066 mag crankcase
« on: November 08, 2020, 09:04:20 PM »
I've got an 066 Mag that I want to rebuild, however, I discovered the pto side case is broken.  I have found a crankcase for a ms660, 066, according to the add for sale.  However, I don't know anything about the quality of it, or if it would work with my 1996 066.  The add says it's made in Italy.  Does anyone know if this would work with my larger diameter crank?
Offline Mad Professor
Re: 066 mag crankcase
« Reply #1 on: November 09, 2020, 10:57:45 AM »
At some point stihl changed the crank and crankcase.
There should be service bulletin on this but I don't have it.  I'd measure up your cases and crank and go to the stihl dealer with case serial #
« Reply #2 on: November 09, 2020, 11:11:04 AM »
Change came in 1996
at serial # X 33 917 065 (02.1996),
You can tell early from late by measuring flywheel side seal
15 X 22 X 4 is later seal, early is 13.5 X 20 X 4
Also I believe early flywheel is aluminum, later is poly
Offline 421Altered
« Reply #3 on: November 09, 2020, 09:30:23 PM »
Thanks for the info.  Are stihl 066 magnum cases still available from Stihl?
« Reply #4 on: November 10, 2020, 12:19:21 PM »
1122 020 2113  later case same as 660
1122 020 2102 early case
Call your Stihl dealer
Offline ZeroJunk
« Reply #5 on: November 10, 2020, 11:29:51 PM »
I wouldn't bet any money that the " made in Italy" case would fit the other case half. There are some other versions that don't show up on the IPL as well. The poly flywheel with the three legged coil case for instance. There are plenty of used 066 cases out there that would not be a gamble.
Offline 421Altered
« Reply #6 on: November 11, 2020, 09:45:33 AM »
Thank you Mad and Professor for that great info!
Offline 421Altered
« Reply #7 on: November 11, 2020, 09:46:00 AM »
Lol!  And Zero too!
Offline ZeroJunk
« Reply #8 on: November 11, 2020, 03:38:35 PM »
Well, I think I misunderstood what you are wanting to do.  I was thinking about just replacing the one case half . I think, which is dangerous, that the round top versions of the 066 and MS660 are the same.
The older flat top versions are different and at least one year of the flat top had a poly flywheel. I had one and I think Holmen has one. I sold mine because I have never seen one of those ignitions for sale.
But, if you have a round top version you should be safe whether it is an 066 or a MS660.
Offline 421Altered
« Reply #9 on: November 11, 2020, 07:52:09 PM »
Zero, Thanks for the update.  I  called my local Stihl dealer today, and they said Stihl says they are out of stock.  The price they quoted was $350.00, and they said that was for a complete, 2 sides case, bare.  But, alas, doesn't look like Stihl will be getting any anytime soon.  I'm just going to see if I can repair it with a product call Belzona, I think that's it.  It's an industrial strength similiar to liquid steel.  I used it to repair my drag race third member.  It has held up through 5 seasons of racing!
Offline 421Altered
« Reply #10 on: November 11, 2020, 07:54:30 PM »
Also, my Stihl dealer said the 066M and the ms 660 shared the same case part number.
Offline 421Altered
« Reply #11 on: November 11, 2020, 07:56:27 PM »
That's later case 066M and ms660 are the same.  As Mad Professor said.
« Reply #12 on: November 12, 2020, 04:00:17 AM »
What part of case is bad?
An option is find good used case pair, clean up and have powder coated.
Offline 421Altered
« Reply #13 on: November 12, 2020, 09:19:05 PM »
It's broken on the clutch side between the rear av mount and the cutout for the chain brake band.  It's broken all the way through that piece.  It was like that when I got it, so, I don't know what happened to it, unless it got dropped somehow.
Offline donbj
« Reply #14 on: November 12, 2020, 11:18:09 PM »
Been following this thread with interest. Curious as to the case repair. I googled the Belzona you mentioned and it looks like an interesting product to re-bond the case on my 2100. Would be a project for sure! Thanks for this info.
Good luck with your repair.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100
066 crankcase
Started by donald_harby on Chainsaws
Last post February 12, 2008, 01:45:34 AM
by joe_indi
Fuel getting into the crankcase?
Started by madmari on Forestry and Logging
Last post March 04, 2016, 08:26:52 PM
by madmari
Fuel in Crankcase
Started by Firebass on Sawmills and Milling
Last post April 27, 2007, 07:37:23 AM
by solidwoods
Crankcase Heaters
Started by TexasTimbers on Sawmills and Milling
Last post December 17, 2007, 07:06:00 PM
by dad2nine
