Dynamic Green Products Inc.
Author Topic: LT 15 Wide full alignment  (Read 234 times)
Offline Woodslabs
  • Check out my wood mill in Toronto
    • Live edge wood slabs Toronto
« on: November 12, 2020, 05:44:42 PM »
Hi All,
I am doing a full alignment and iv ran into some issues.
- I replaced the blade wheel belts and put a blade on (no rollers)
- I set the mill to 15 inches
On the Drive side the mill is 15 and 1/4 before roller deflection.  The idle side is 15 and 1/8.  I called woodmizer and they told me that i need to tilt the idle side wheel.
Maybe the mechanism is broken on my mill but I tried turning both bolts  in and out and not much happens.  Manual says 1/4 turn.  I find that if i tighten the bottom bolt when there is resistance i can tilt the wheel more out of position.  The top bolt only gains resistance when its almost all the way in.  when I measure with the clip on blade measuring tool and a straight edge the best i can do is being a 1/8 off from one side to the other (with straight edge across the bed .
Also playing with the tilt did not solve my issue of being at 14 and 1/8 without deflection.
Can someone explain how the tilt mechanism works on the idle blade wheel?  is it the same as the blade guide rollers?
Offline Woodslabs
Re: LT 15 Wide full alignment
« Reply #1 on: November 12, 2020, 07:15:34 PM »
I messed around with it some more and got it to even out.  I noticed however that the tracking bolt moved down as I adducted the wheel tilt.  Is this normal?
Offline busenitzcww
« Reply #2 on: November 14, 2020, 09:13:13 PM »
I thought there was a bolt you could tighten that held the bearings that ride up and down on the drive side? This would cause the whole head to become parallel with the bed? Maybe Im miss understanding?
Saw alignment question lt15 wide
Started by Woodslabs on Sawmills and Milling
Last post December 07, 2015, 05:39:11 PM
by Ga Mtn Man
LT15 Wide, LT70 Wide, where's the Wide Edger?
Started by Dave Shepard on Sawmills and Milling
Last post March 25, 2018, 11:53:41 PM
by Darrel
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
Wide plank flooring...how wide can I go?
Started by lshobie on Sawmills and Milling
Last post January 13, 2016, 08:34:59 PM
by Rob in NC
