Dynamic Green Products Inc.
Author Topic: Sawing Multiple Boards Between Offloading  (Read 1033 times)
Online Pepe_Silvia
« on: November 14, 2020, 11:06:26 AM »
Using a LT15Wide.  Cutting a lot of wide, heavy slabs.  Can I cut multiple slabs without offloading and leave them stacked, or does the weight on top become an issue?
I was doing it this way for a while because it was more efficient and then ran into some issues cutting a live oak log where it seemed like the blade was getting really hot and took a dive.  This might have been coincidental to leaving the slabs stacked (it was live oak, afterall).
Offline kelLOGg
Re: Sawing Multiple Boards Between Offloading
« Reply #1 on: November 14, 2020, 12:03:46 PM »
I don't saw wide but I frequently off load after all is sawn. If the blade set has not worn down I don't think heating due to friction will be a problem. I haven't detected a warm blade on my mill but I don't saw as wide as you.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Online Southside
    • White Oak Meadows
« Reply #2 on: November 14, 2020, 12:25:16 PM »
Not a problem to do that. The weight is not a factor as the kerf remains open from some of the sawdust left behind.  The dive was likely due to the band getting dull considering you were sawing live oak.
White Oak Meadows
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: November 14, 2020, 12:44:32 PM »
   I agree with Southside. It would appear to be no different in leaving a couple of extra 8/4 slabs on top than choosing to cut a 4" or 6" thick single slab the way I see it.
  I often leave several boards, slabs or flitches on top of the cant when sawing if it is more convenient than removing each at the time of cutting. The only slowdown I experience in doing so is the delay of having the raise the head a little higher before returning it to the front of the mill.
Offline JoshNZ
« Reply #4 on: November 14, 2020, 01:33:21 PM »
If I'm sawing multiple boards off same log/cant I leave them there until I feel like the time spent climbing and falling the stack becomes less efficient than just offloading. Weight can help keep things straight if you're getting close to the bed too.
Offline donbj
« Reply #5 on: November 14, 2020, 02:21:14 PM »
I saw cants up all the time leaving the boards on til it's done. The blade cannot get pinched as the solid wood in front of the blade will not let it. The blades aren't wide enough to be a problem further back.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100
Online Larry
    • Copas Sawmill
« Reply #6 on: November 14, 2020, 04:07:51 PM »
I've sawn well over a 1,000 slabs this year from 2 - 3" thick.  Up to 14' long and 32" wide.  I've learned slabs are heavy!  Some are too heavy for even two men to lift
Normal routine is to saw slabs from the top to close to the pith.  Rotate log up so the slabs slide off onto either the mill loader arms or the forklift forks.  Rotate the rest of the log 180 degrees and slab down to the bed.  Repeat the routine of sliding the slabs off the mill onto the loader arms.
I hardly ever lift even one end of a slab.  Its all push and slide work.
With your manual mill I would quickly figure out a system that would not require heavy lifting.
Offline Walnut Beast
« Reply #7 on: November 14, 2020, 09:15:05 PM »
Nice tips Larry 👍👍
« Reply #8 on: November 14, 2020, 09:20:53 PM »
Are you centering the pith in the middle of the last slab or making something different
Online Larry
    • Copas Sawmill
« Reply #9 on: November 14, 2020, 09:39:01 PM »
I split taper and try to keep the pith in one slab.  Sometimes I make close misses but it doesn't seem to make much difference to the buyer.
My first consideration is getting the best figure out of the crotches, second is the widest slab possible, and third is the pith.
Offline ladylake
« Reply #10 on: November 15, 2020, 04:31:46 AM »
 With the rustic look now days I've had customers tell me they like the pith.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline dougtrr2
« Reply #11 on: November 15, 2020, 08:53:06 AM »
I am not a sawyer, but had that same question after I had some logs sawn.  I was surprised that we didn't offload each board.  Later I ran across a Youtube video that was made to answer that question.  As part of the demonstration the sawyer made several cuts without off loading.  The he made a cut, shut the saw off and was able to back several inches into the cut just made.  That convinced me.
Doug in SW IA
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #12 on: November 15, 2020, 09:03:13 AM »
smiley_thumbsup smiley_thumbsup
X2
When sawing big slabs, and lots of them, I change our normal technique and even reconfigure our roller tables when getting serious about slabbin'.  Last week, while taking a break, I pulled out the Forum calculator and figured I was sitting on a pallet full of 200+ pounders.  Multiply that by the 6 pallet fulls I'd already done that day, and more to come, definately take "steps to save step".  For scale, the short slabs on the back row were "only" 8 footers.
Sawing multiple boards before offloading is one of those steps.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline Sixacresand
« Reply #13 on: November 15, 2020, 09:42:49 AM »
Normally, I flip the boards off the cant as I go, so I can inspect the last cut.
Off your bottom and on your feet, out the shade and back in the heat! Back to work boys!
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #14 on: November 15, 2020, 09:58:03 AM »
On portable jobs with good help, I dont saw multiple boards in a cant due to the time it takes to jog the head up at the end of the cut.  That time mounts up over the course of several hours.  For customers time = money.  Usually I like to cut one board, leave it on the cant until I start the next cut, off bearers pull the top board off (from behind me) as I cut the next and so on.  I stay one board ahead and it gives them time to clean, stack and sticker properly.
Sawing slabs is a different situation as has been pointed out already.  I often reposition the log after cutting 2 or 3 slabs off the top much as others have mentioned.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Online GAB
« Reply #15 on: November 15, 2020, 02:40:40 PM »
"That time mounts up over the course of several hours.  For customers time = money."
If more customers were former students of time and motion study the boards would be moving the minute the saw blade breaks through.
GAB
Online WV Sawmiller
« Reply #16 on: November 15, 2020, 03:15:42 PM »
  I have tried the off-bearer behind me and no more. They tend to slow me down, I trip over them, they are a distraction and a safety hazard for me. The last mobile job I did I had the best help ever - the customer and his hired helper. They off loaded off the end and the loader side. I'd push the board on to the bed then back up and start the next cut.  One stack we made on the operator side and they unloaded those from that side. I almost always unload off the end vs the front of the mill. If I had and used a board return I'd have to revise my system but this works good for me. When working alone I park my tractor with the forks or my trailer near the end of the mill and slide the finished boards off onto it.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: November 15, 2020, 06:23:32 PM »
Not only did I remove the board return from my sawmill, I do not allow any offloading, etc. behind me nor out of my sight.  That way I know where everyone is at all times.
Offline forrestM
« Reply #18 on: November 15, 2020, 09:11:58 PM »
i have an lt15 wide, and I will often leave slabs on the mill until the throat has no more clearance.
it seems like it is usually a time saver. however, like with your blade taking a dive - it you arent taking off and glancing at each each board, it's easy to continue sawing on a dull blade when you shouldn't be. I ruined a stack of wide poplar boards the other day by doing that. From my limited experience, wide cuts will really exaggerate a dull blade and it seems like they will go from kind of dull, to terrible in an instant.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #19 on: November 16, 2020, 08:19:25 AM »
I have let boards stack on the cant until the cant was completely sawn!
I have done so when the cant would be inclined to move after each cut!  :)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Production sawing- which end of mill offloading
Started by Bigsticks on Sawmills and Milling
Last post August 06, 2015, 09:58:33 PM
by 4x4American
Question ?  sawing multiple posts from log .
Started by WV_hillbilly on Sawmills and Milling
Last post February 09, 2005, 06:51:59 PM
by Buzz-sawyer
sawing 1 1/2 boards?
Started by yellowrosefarm on Sawmills and Milling
Last post May 08, 2020, 02:20:04 PM
by alan gage
sawing boards
Started by thedeeredude on Sawmills and Milling
Last post September 18, 2005, 10:53:57 AM
by Tom
