Dynamic Green Products Inc.
Author Topic: 1.25 inch blades vs 1.5  (Read 1074 times)
Offline Southside
    • White Oak Meadows
Re: 1.25 inch blades vs 1.5
« Reply #20 on: November 18, 2020, 08:22:45 AM »
That makes sense, never thought of it that way.
White Oak Meadows
Offline donbj
« Reply #21 on: November 18, 2020, 01:11:02 PM »
My curiosity is trying the 1½" blades but staying with the .045.
Three of us tried the .055X1¼" blades when we were sawing the goodwill project for Willie Steele with the same disastrous results.  :-X
I think you will like the MM. I changed over to them years ago. I use the 1.5 x .045's. The difference was quite noticeable a far as how much more they could be pushed even though I only have the 24hp onan. They can be pushed a little harder longer. You having more hp will be a good thing. Sawing in dirtier wood I noticed they would last longer than the 1.25's before being changed. Gotta be extra careful doing blade changes as the room is limited.
I saw no where near what some of you do but used to portable custom saw. Just more hobby for me now.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #22 on: November 18, 2020, 07:02:19 PM »
I have two 1½"X.045, T7° blades on the way.
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
« Reply #23 on: November 18, 2020, 07:24:07 PM »
I'm with MM. I've got two coming as well.
Looking for more "beam" strength on the 40 wide. Still running the 1&1/4" roller guides so may be hoping for to much.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #24 on: November 18, 2020, 07:54:16 PM »
I just received two new blade guide rollers this week.
They were labeled for 1¼" and 1½" blades.
Offline hopm
« Reply #25 on: November 18, 2020, 07:55:49 PM »
I took the guides off...upped blade tension....and run 1 1/2” blades on a 16 hp Baker...definitely a huge improvement
Offline Patrick NC
  • I'm not new anymore, but still pretty green
« Reply #26 on: November 18, 2020, 08:40:30 PM »
I ordered two 1.5x.045 double hards in standard 7 degree today. If they don’t work for me at least my curiosity will be satisfied.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Offline Southside
    • White Oak Meadows
« Reply #27 on: November 18, 2020, 08:45:18 PM »
The regular 7's do pull easier than the turbos, sounds like a good plan. Will be interested to see how they work for you.
White Oak Meadows
Offline Patrick NC
« Reply #28 on: November 18, 2020, 09:14:35 PM »
The Kasco 7s have been working real good for me. So I can experiment with some other blades and if it doesn’t work out I’ve got something to fall back to.
Offline donbj
« Reply #29 on: November 19, 2020, 03:05:32 AM »
I run my stock guides and they do fine.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #30 on: November 19, 2020, 04:20:52 PM »
I tried some 1-1/2" x 0.045 x 10° WoodMizer blades a while back and they let me saw a little faster in wide Douglas-Fir with a 28 HP EFI engine. That was in 2008. The only issue I had with running 1-1/4" mixed with 1-1/2" blades was that I had to adjust the guide rollers back about 1/8" with the wider blades. So yes, those 1-1/4" rollers work with both, but you can't just switch blades.
The following year my friend, John, switched from 1-1/4" x 0.045's to 1-1/2" x 0.050's using the same mill. He found he could really push the blade, but he also mentioned he'd bought 1-1/2" wide blade guide rollers. I didn't know they made them.
So ... after I used the last of my 1-1/4" blades, I bought the new rollers and I've been sawing with the wider blades ever since.
I ended up sharpening John's blades for him, and I dislocated my shoulder (seriously) trying to fold those thicker blades :o.
Bottom line, with a 28Hp gas engine I'm happy with the 1-1/2" x 0.045 blades, but I wouldn't use anything thicker.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
I need some 2 inch 055 blades
Started by just_sawing on Sawmills and Milling
Last post October 12, 2010, 10:15:46 PM
by sgschwend
10 inch saw blades. What do you recommend?
Started by 21incher on General Woodworking
Last post November 12, 2016, 03:39:55 PM
by 21incher
4 or 5 inch wide Band Blades ??
Started by Tobaccoman on Sawmills and Milling
Last post May 09, 2013, 09:39:05 PM
by isaacpopp
31 inch to 25 inch Western Red Cedar on the Manual LT 35
Started by Ruffneck on General Board
Last post March 16, 2017, 02:50:23 PM
by Ruffneck
