Author Topic: Another Sawmill Shed,,,Finally  (Read 2162 times)
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Another Sawmill Shed,,,Finally
« Reply #20 on: January 07, 2021, 12:49:06 PM »
   You know it is not going to be big enough. :D Looks real good.
    My very best to your dad. My 90 y/o mom was just released Christmas Day after 5-6 in the hospital for C-19. She and my 450+ lb brother both seem to have recovered from it in spite of their ages and health risks.
Offline boonesyard
  • I've got a little sawdust in my pocket
« Reply #21 on: January 07, 2021, 01:01:34 PM »
I could put a cover over an acre and it wouldn't be big enough whiteflag_smiley. I've got an old barn on the place (only original building left) that is beyond repair. I'd REALLY like to take it down and put up 60 x 100 cold storage in it's place, but that's a whole different animal. This year we're going to have to do something for climate controlled kiln dried lumber storage,,,,,, what have I gotten myself in to  :o. Lovin every minute of it!
I'm glad to hear your mom and brother came out of it. It's weird stuff
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Offline Walnut Beast
« Reply #22 on: January 07, 2021, 03:13:22 PM »
Beautiful shed but i disagree on the concrete . It is low here in south ga and for years i have dealt with uneven ground and water . Last year i pored it all including my shop. I don't saw full time and don't have a blower yet. I saw for 2 days put the bucket on my skid steer and in 15 minutes it is gone. The best part is stacking , it is so much better on concrete than on the ground.
Absolutely. Anybody that’s making excuses to not put concrete in or out of their building is making excuses. It comes down to cost. Yes it’s expensive. The upside is absolutely incredible. Ask anybody with a concrete floor in their shop. If your going to go heavy on the floor you can go thicker on the concrete in the middle like 6”or 8” and towards the walls 4” where your not going to have as much weight. A power troweled floor is extremely nice but more expensive
Offline boonesyard
« Reply #23 on: January 07, 2021, 04:52:29 PM »
Absolutely the concrete comes down to cost. I know all about it, my other company is  municipal water and wastewater treatment construction and our bread and butter is heavy structural concrete (we place 2,000+ cy yds/yr.) and process mechanical. Some day there may be concrete in it, but there is no question that walking back and forth and around the mill on class 5 is easier on my back than on concrete all day.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline firefighter ontheside
  • I like trees.
« Reply #24 on: January 07, 2021, 05:58:53 PM »
Awesome shed you're building here.  I sure hope your dad gets well and comes back to work on it with you.  I sure would like to have something like this, but then I'd need to include my woodworking shop with it as well.  I don't think you can do better than Sikkens Cetol for your stain, but its mighty expensive.  Might be cheaper to put up the metal.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline boonesyard
« Reply #25 on: January 08, 2021, 10:55:21 AM »
After a bit of consternation, I've decided to go with steel wainscoat on the bottom 4' of the walls. The input here on the forum is excellent and after coming this far with the project, it makes sense to have the steel on the bottom. Just ordered it and it's about 3 weeks out.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline AK Newbie
« Reply #26 on: January 08, 2021, 11:55:29 AM »
Thanks for sharing this build, it is truly inspirational! More positive thoughts from the last frontier for your Dad, if anyone can pull through C-19 he sounds like he can.  Here's to putting that chapter behind him!
LT28, Logosol M7, Husky 385XP, Stihl MS 250, Echo
Offline Andries
  • Making buildings out of big curvy logs
« Reply #27 on: January 08, 2021, 12:06:09 PM »
After a bit of consternation . . .
From time to time, I've found that a bit of "construction consternation" is helpful.
Good move, you won't regret the wait.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline boonesyard
« Reply #28 on: April 08, 2021, 03:46:57 PM »
Just a quick update on the shed progress. The metal wainscoat was absolutely the way to go.
I also decided to put a concrete floor in the lean-to before closing in the walls, a lot easier to finish around the posts now. We're going to enclose and insulate this part of the building and use it for dried lumber/slab storage/display. It's coming together slow, but sure.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
« Reply #29 on: April 08, 2021, 03:56:04 PM »
Looks good. Smart move on the concrete
Finally starting my sawmill shed.
Started by ForestMan on Sawmills and Milling
Last post December 23, 2010, 10:42:48 PM
by ForestMan
Finally got my saw shed built
Started by oakiemac on Sawmills and Milling
Last post January 20, 2010, 06:08:36 PM
by oakiemac
Mill Shed - Finally
Started by ncsawyer on Sawmills and Milling
Last post November 19, 2019, 08:16:42 AM
by ncsawyer
I finally found a shed
Started by thecfarm on The Outdoor Board
Last post May 22, 2019, 05:13:53 AM
by thecfarm
