Dynamic Green Products Inc.
Author Topic: Covering My Timbers?  (Read 220 times)
Offline PRC
  • Putting the K in Kustom
« on: November 20, 2020, 11:19:33 PM »
Hey guys,
Well, I went and did it.  I've been lurking around here for years, and have built a couple of small projects.  I've had an entire 36x24  barn worth of beams delivered to my property.  I'm in the process of setting up my work area, and will start cutting in the next few days.
Before you get too excited, I'm not doing a true timberframe.  I decided to go with the T-Rex connectors.  It'll give me 90% of the look I want, but it'll save me a considerable amount of time, and since I'm working mostly alone, it won't take me 20 years to finish.
I've been letting the lumber breathe for the last few days (It came wrapped).   I'm going to get everything stickered this weekend.  I'm looking for a cheap way to cover them.  I know folks have mentioned metal sheets in other posts.
Any thoughts on those cheap blue tarps that they sell on the big box stores being used to cover the wood?  I was thinking of more or less strapping them down and keeping the "sides" open so air can flow over the wood.
I live in a cold climate, and the snow will be here before we know it, what are your thoughts?
I have no idea what I'm doing, but if I keep reading and making mistakes, I just might get somewhere.
Offline doc henderson
Re: Covering My Timbers?
« Reply #1 on: November 21, 2020, 10:37:14 AM »
at first I thought you meant it was in the barn,   :).  has it been dried in some way or green?  any cover to block sun and moisture.  if green will need stacked and ventilated.  if it was air dried to 12%, maybe just wrap it back up so it is accessible.  my first thoughts.
Online Don P
    • Calculator Index
« Reply #2 on: November 21, 2020, 04:04:56 PM »
Brad's pallet covers are the best way to go. Make pallets large enough to cover the piles and put tin, blue tarps, lumberyard bundle wrappers, etc secured to the top of those. Tarps on piles get torn up and end up just trapping moisture.
Offline PRC
« Reply #3 on: November 21, 2020, 10:29:49 PM »
They're green.  Stickered most of them today.  Stickering the rest tomorrow.
Milling own timbers vs ordering timbers from a sawmill
Started by Joe Vachon on Sawmills and Milling
Last post July 03, 2017, 12:45:18 PM
by thechknhwk
question
Hardwood timbers vs. Softwood timbers
Started by jeremy86 on Timber Framing/Log construction
Last post September 23, 2016, 09:01:22 AM
by Heartwood
covering wood?
Started by hisliptree3 on Firewood and Wood Heating
Last post September 24, 2011, 01:26:45 AM
by CRThomas
Covering a frame
Started by FrankLad on Timber Framing/Log construction
Last post December 07, 2006, 01:37:23 PM
by FrankLad
