Sawmill Shed Pole Building
Started by TimW, November 23, 2020, 10:06:38 PM
0 Members and 4 Guests are viewing this topic.
TimW
TimW
I won't need to stick that Bull of a Lull in the barn when I am building the trusses to flip them. Thou I might because I can.  Right about 15 feet is this beam I put in two years ago to take the sub frame off of my Mahindra to split it for clutch R&R.  A come along would do the lifting if used.
jpassardi
Quote from: TimW on June 07, 2025, 10:58:17 AMRough is better is what I was thinking. Based on we sanded before bonding composites, fiberglass and adding paint to an existing paint job.
As to best adhesive, Project farm didn't say Locktite. https://project-farm.com/pages/project-farm-favorites
But  Best Construction Adhesive: We Tested 10 to Find the Strongest says Locktite Premium is the bestest.
This is what I was referring to:
https://www.youtube.com/watch?v=hukFoQ4GIk8
Skip to conclusion if you just want the summary. He does sound Engineering based testing.
doc henderson
great info.  the Leech company is here in Hutchinson, I think.  Unless there are more than one.
jpassardi
Do they make adhesive for Loctite Doc? I do know Loctite is owned by Henkel here in Rocky Hill CT.
Always good when you can support a local company.
doc henderson
I assume not, but around here, f26 is the greatest due to the local business.
