Sawmill Shed Pole Building
Started by TimW, November 23, 2020, 10:06:38 PM
Nealm66
Will be interesting to see if the plastic sleeves work. So wet around here. I'd wonder if they'd still rot because of the moisture trapped inside. Gotta keep them above ground with metal here even with the ground contact treated if you really want them to last. The newer environment friendly treatment isn't near as good as it used to be. I've thought about roofing tar to seal, old farmer said it helps but they still rot
