Dynamic Green Products Inc.
Author Topic: Can You Help Identify This Old PTO Winch??  (Read 878 times)
Offline cl5man2
« on: December 03, 2020, 10:45:49 AM »
First time user here, hope I'm in the right forum for this. Purchased an old military PTO winch some time ago with the intentions of attaching it to my skid steer. The time is right, so I've started the conversion to hydraulic. Its made by Allstate which was a re-branded Braden winch. I've searched high and low on the net and just cannot determine the model and specs on this winch. It looks identical to several of the Brayden winches so I'm hopeful someone might recognize it. I'm trying to size the hydraulic motor and really need to know how much pull this winch can take so I can use all of its capacity. Plenty of hydraulics to power this thing, 3300 psi and 23 GPM available. Obviously its in need of repair but nothing I cant handle. It came from Fort Huachuca down here in southern AZ, its a beast!! Weighs about 150 lbs with no motor or cable. I'm hoping its in the 20k range. Let me know what you guys think. Thanks
Offline mudfarmer
  • Mama Tried
Re: Can You Help Identify This Old PTO Winch??
« Reply #1 on: December 03, 2020, 11:26:22 AM »
What are the #s stamped into it? I can almost see them.
This page says top will be model and bottom is serial #, first two digits are year of manufacture
BRADEN WINCH SERIAL NUMBER | Winches, Inc.
Yours looks like the M3H worm drive they have a picture of
Offline cl5man2
« Reply #2 on: December 03, 2020, 11:49:44 AM »
Top row has 428-4944-L stamped in it.  Bottom row has 491209 stamped in it.  That would be cool if the winch was a 49'.  Things were build different back then.
Offline mudfarmer
  • Mama Tried
« Reply #3 on: December 03, 2020, 01:22:11 PM »
I don't know if it is a Braden, it could an early Ramsey. It looks like Sears resold both Braden and Ramsey winches under the Allstate and Sears names. Possibly some variant of Ramsey model 101.
Looking forward to someone that can help give you a positive ID.
Online Walnut Beast
« Reply #4 on: December 03, 2020, 02:12:05 PM »
I had one like that I never used. The other one was a factory winch on the front of a 1948 Dodge Power Wagon.They were Braden MU 2 . I think thats what it is like
Offline Larry
    • Copas Sawmill
« Reply #5 on: December 03, 2020, 09:47:11 PM »
I'm thinking Braden also.  A lot of forestry vehicles had front mounted pto winches.  I have an old Ramsey off a USFS truck that I don't think was ever used.
Online mike_belben
  • Pulp Friction
« Reply #6 on: December 05, 2020, 01:20:11 AM »
Dont overthink it.  Spec the motor that can handle all your fluid psi and gpm and give you a good line speed.  You can figure the gear ratio by counting turns.  No need for brute power at the expense of speed.  If the log is THAT big youll just pull the skid steer to it anyways.
A hydraulic 12k will reel in all that a bobcat wants to drag anyway.
Revelation 3:20
Offline DbltreeBelgians
« Reply #7 on: December 08, 2020, 09:46:19 PM »
I can say with confidence that is a Braden. The gearbox side of the winch is nearly identical to the Braden
MU-2 I built for my S-250 Bobcat. It has a manual clutch for engage and free spool with a brake pad to stop the drum from spinning out of control during free spool causing a rats nest. Mine came from a wrecker truck and had a divider in the center of the drum which I removed. It was hydraulic drive with a u-joint. The gear motor tied up so I designed an adapter and made a direct drive coupling. I can stall it out but the gearmotor which is a Parker is fairly small. I dont worry about breaking anything because of that. It has 150 of 3/8 stainless aircraft cable on it and Im sure it would hold 250 easily.
Parts are readily available on eBay to rebuild it.
Brent
Online Walnut Beast
« Reply #8 on: December 09, 2020, 12:19:09 AM »
Nice winch setup 👍
Online mike_belben
  • Pulp Friction
« Reply #9 on: December 09, 2020, 07:51:34 AM »
I like it but i also wish you had a cable catcher screen of some sort.. I know its probably never gonna break but still.  It would be horrible to eat a face full of frayed wire at 200mph.  Please consider it.
What model bobcat?  Wheel or track?
Revelation 3:20
« Reply #10 on: December 09, 2020, 06:56:04 PM »
Yes it does need some sort of screen. Thats as important as guards on a band mill. Its always a work in progress.
Its mounted on a 2006 S-250 Bobcat wheeled machine
Brent
need help to identify winch
Started by pacodog on Forestry and Logging
Last post November 07, 2006, 08:27:41 PM
by thecfarm
Can Anyone Identify This Winch?
Started by SliverPicker on Forestry and Logging
Last post January 17, 2014, 07:50:18 PM
by SliverPicker
question
Help Me Identify This Gearmatic Hydraulic Winch
Started by Dangerous_Dan on General Board
Last post January 15, 2007, 10:46:39 PM
by KGNC
Help Identify Tulsa Winch with Capstan
Started by IamTicketMan on General Board
Last post December 09, 2011, 05:19:13 PM
by Ironwood
