Author Topic: Homemade saw mill#2 (*update* homemade energy chain ??)  (Read 12277 times)
Offline mike_belben
  • Pulp Friction
Re: Homemade saw mill#2(power Toe board finished)
« Reply #120 on: May 23, 2021, 01:18:43 AM »
Theyre probably sealed for a chair in the rain scenario.
Isaiah 63:10
Offline Vautour
Re: Homemade saw mill#2(water tank installed)
« Reply #121 on: June 18, 2021, 08:40:37 PM »
Found this in the garbage,. a water softener tank for my water tank,.. perfect....
the Gospel is WANTED by the people in 52 Countries but made illegal by their Government
Offline JoshNZ
« Reply #122 on: June 19, 2021, 05:06:38 PM »
Is that for blade lube? Mines about 3 litres! You'll only need to fill it once a year at that rate
Offline Vautour
« Reply #123 on: June 19, 2021, 08:36:05 PM »
@JoshNZ.... after reading your comment and laughing my head off,.. maybe i over shot my water tank by a few litres :D....but it did make me rethink and that i could use that tank for my fuel and build a smaller water tank,.. boom new plan.
Offline JoshNZ
« Reply #124 on: June 22, 2021, 07:53:22 AM »
That's still looks about 3x as much fuel as I carry with a vtwin engine haha. But yup, who likes stopping to refuel
Offline mike_belben
  • Pulp Friction
« Reply #125 on: June 22, 2021, 04:16:33 PM »
Cut it in half, baffle it and glue it back together. Water on one side fuel on the other.
Isaiah 63:10
Offline Vautour
« Reply #126 on: June 23, 2021, 08:24:24 PM »
Mike if it was stainless steel i would consider it and the fiberglass work!! i don't want to chance it.... meanwhile as i continue to cut, grind, weld, scratch my head, weld some more... still hoping for the elusive smell of sawdust.. soon.
Offline Vautour
Re: Homemade saw mill#2( installing blade covers)
« Reply #127 on: July 08, 2021, 05:14:20 AM »
building blade gardes out of a old old electrical box i had,..
Offline Vautour
Re: Homemade saw mill#2( adjustable bunks installed)
« Reply #128 on: August 03, 2021, 04:57:46 AM »
chopped some I-beams for my bunks and welded a 1'' SS angle on top with two adjustable threaded rod on each. end.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #129 on: August 03, 2021, 06:35:43 AM »
That is very nice. I was thinking about a stainless steel U cap but the angle will work nicely.
Online thecfarm
« Reply #130 on: August 03, 2021, 06:44:45 AM »
You will like the movable bunks!!
Offline mike_belben
  • Pulp Friction
« Reply #131 on: August 03, 2021, 01:05:06 PM »
Heck yeah
Isaiah 63:10
Offline Vautour
Re: Homemade saw mill#2( finally painted)
« Reply #132 on: October 10, 2021, 07:51:14 AM »
now comes the more technical phase..MAKING IT WORK
Offline mike_belben
  • Pulp Friction
« Reply #133 on: October 10, 2021, 09:32:24 AM »
I never realized the square/round/square stacked construction you built the bed with.  That is one rigid son of a birch. Nice job.
Isaiah 63:10
Offline JoshNZ
« Reply #134 on: October 10, 2021, 09:58:26 AM »
Sure looks tidy!
Offline Vautour
Re: Homemade saw mill#2( swing command post done)
« Reply #135 on: November 11, 2021, 05:51:59 PM »
 <br
Ready for the wiring.
Offline fluidpowerpro
  • Hi there!
« Reply #136 on: November 11, 2021, 08:59:02 PM »
Looks great. You do nice work.
Change is hard....
Offline Iwawoodwork
« Reply #137 on: November 12, 2021, 12:12:23 AM »
Vautour I hope you left enough room in your guards to install something to keep the blade teeth from contacting the steel guards, I used free rubber conveyor belting after screwing up 5-6 blades that came off the wheels due to various newbie mistakes. Gets spendy $$$$ when learning. The blades can come off both front and back, Off front and teeth hit the guard, instant dull, Off backwards and the teeth hit the band sheave tire wheels and dull and/or screw up the set.  I pop riveted with aluminum pop rivets  through the belting. Wood or plastic, uhmv would also work
Offline Gere Flewelling
  • Hobby Miller
« Reply #138 on: November 12, 2021, 08:16:06 AM »
Before the paint it was a thing of quality for sure.  Now all painted up, it has transformed into a thing of beauty. 8)
I hope it will work as good as it looks.  Thanks for sharing pictures of your build.
Old 🚒 Fireman and Snow Cat Repairman
Matthew 6:3-4
Offline Vautour
« Reply #139 on: November 12, 2021, 06:22:16 PM »
 Iwawoodwork ... eventually there will be plywood on the inside of my doors and in all the back guards for sure.
tks... eventually i'll get there..looking good for 2022..
Chain Turner - homemade
Started by Puffergas on Sawmills and Milling
Last post July 06, 2009, 07:29:13 PM
by Puffergas
Who's homemade mill?
Started by Woodchuck53 on General Board
Last post May 25, 2008, 11:38:59 PM
by Woodchuck53
Homemade mill vs. big log!
Started by chevytrucking on Sawmills and Milling
Last post June 01, 2018, 02:36:49 AM
by fishpharmer
My Homemade Mill.......
Started by fishingmike on Sawmills and Milling
Last post May 04, 2016, 09:12:22 AM
by Ox
