Author Topic: tension on Kasco bands  (Read 1419 times)
Offline kelLOGg
« on: December 13, 2020, 09:32:16 AM »
I have a Cooks MP32 with no gauge but a compression spring for tension. I want to use the caliper method for setting/checking tension but need to know what the reading should be. I am using Kasco bands 0.045" thick, 4°, 1.25" wide. Thanks.
Offline Cutting Edge
    • Cutting Edge Saw Service, LLC
Re: tension on Kasco bands
« Reply #1 on: December 15, 2020, 09:29:48 PM »
kelLOGg
.0035"-.004" using a 6" caliper opened to  5-1/2" +/-
Should give you approx 20,000-21,500 lbs/strain on the blade
Hope this helps ya out
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Offline kelLOGg
« Reply #2 on: December 18, 2020, 07:27:13 PM »
Thanks!
CBN wheel for kasco 4 degree bands
Started by JoshNZ on Sawmills and Milling
Last post August 06, 2021, 03:02:06 AM
by Cutting Edge
Ordered bands from FF sponsor Kasco Canada
Started by RAYAR on Sawmills and Milling
Last post June 07, 2019, 01:47:37 AM
by RAYAR
lbs of tension on your bands
Started by New Brunswick on Sawmills and Milling
Last post May 08, 2008, 11:10:00 PM
by eamassey
Old bands or band tension?
Started by shinnlinger on Sawmills and Milling
Last post August 15, 2020, 05:37:01 PM
by Wintergreen Mountain
