I have 5 or 6 battery tender juniors kicking around that are on the tractor, mini ex, SxS, etc. They work good.In my trucks, I switched over to AGM batteries. The battery tender juniors do not charge AGM batteries correctly. The Battery tender Plus is for AGM batteries. I bought a NORCO smart battery charger, which will charge any battery. It also has a repair mode that I have used successfully to bring back two dead batteries. That function alone paid for itself. Offsite photo removed by Admin.
Anyone using solar chargers?
If I recall, it's something about a faulty diode
I would guess it's more than just the presence, absence or a malfunctioning diode. I would assume the charger has to sense the battery status to charge properly and that requires a diode free line from the battery which could draw down the battery if there is no sun power for extended periods. It's kind of a dilemma without a good answer.
On my motorcycle I’m using an Optimate3 on the recommendation of my motorcycle and ATV mechanic. It does very well but I’m not convinced it’s better than the Battery Tender Jr.
Quote from: SawyerTed on December 16, 2020, 02:55:57 PM On my motorcycle I’m using an Optimate3 on the recommendation of my motorcycle and ATV mechanic. It does very well but I’m not convinced it’s better than the Battery Tender Jr. The box I have here must have been rebranded because it has Honda on the box as well as Optimate3. I see some other stuff on your box is a little different. But mine was that marked price in CDN$, which would be US$20 cheaper.
Started by Furby on General Board
Started by glgdiggs on Sawmills and Milling
Started by Knute on Sawmills and Milling
Started by Bruno of NH on General Board
