Rock ID
Started by Bibbyman, May 29, 2002, 01:44:01 PM
0 Members and 5 Guests are viewing this topic.
Bibbyman
The daughter of a friend found this unusual "rock" in among the gravel in a local stream.  He took it to an Indian artifact expert(?) and was told it was only a common rock.
What you can't see is that the hole goes almost to the bottom and it is perfectly concentric and symmetrical in all details.
Sawing since '94
Corley5
Very interesting.  Just a common rock?  More likely it's a rare Indian Sex Stone ;D
It looks similar to the rock I posted on here last year for a "what is it". Our local indian experts (MMCC) told me mine was a fire starter rock. Put tinder in the hole, then grind a stick in there till the heat catches the tinder to glow.
Corley5
It could also be a medicine rock.  We've got one that is different than that but the principle is the same.  The cavity was used to hold herbs, roots, berries etc to be ground and mixed for medicine.
Methinks you need another expert. :P
My humble opinion is that Barney Rubble lost a lugnut. Ouch!
CHARLIE
Your Rock Exspurt don't know squat. I'd say it was an Indian artifact of some sort. Now I've done some studying and I think it is what the ancient Indians used to chalk their Cue Sticks when playing pool. ???
Charlie
Is it an exploding wedge?
Bibbyman
I asked my friend if the "expert" offered him .25 for it after he said it was common rock.  The friend said no,  he didn't offer to buy it but he did ask where it was found.  Another guy with some experience said it was used as a paint bowl.  smiley_indianchief
It's a little hard to see the little groove around the outside – forming a thick rim.  I wondered about that.  Surely it was not for decoration but then I thought a string or thong could be tied around that groove so it could be hung or tied to something.
Sawing since '94
Will you look at that. A smiley for every occasion
Ron Scott
Looks like an indian paint bowl. Let one of the local archaeologists looks at it.
~Ron
Sawyerfortyish
I think corley5 was right with the first guess a rare indian sex stone used as the first form of birth controll :o ;D
Bibbyman
Our farm has no shortage of rocks.  The hill parts being covered with what's call glacier deposits.  It's not unusual to find about any kind of rock on our farm.  But son Gabe came in with one that's a bit unusual. It's very heavy and hard.  I thought it may be some kind of iron but a magnet does not stick to it.  It looks about like fresh raw liver in color and texture.  It must be some kind of sedimentation rock as there looks to be a fern leaf imprint on one side.
Any ideas?
Sawing since '94
wudhed
Bibby,
I sent the pictures to a friend of mine who is a indian artifact expert. He said that is called a discoidal it is a smudge. It was used for the paints that they would put on their faces for ceremonies. He also said to hang on to it because it is worth some big bucks! HE said he had never seen one hat small or in that good of shape before so hang onto it!
Derek
Proudly building quality timberframes since 1981!
Bibbyman
Quote from: wudhed on July 24, 2008, 02:36:02 PM
Bibby,
Derek
I only hung on to it long enough to take the picture.  In fact,  I didn't even hold it then.  It belonged to another man that brought it into work.
Sawing since '94
arojay
A few years ago I found a square chunk of dark basalt rock, about an inch and a half square(ish) and about an inch thick with a similar round hole or pocket in it that still had a little round white quartz rock in it.  I found it on a stream bank and the round rock had obviously rolled around on the square one for quite some time and wore itself a home.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
Bibbyman
Quote from: Bibbyman on July 24, 2008, 10:54:19 AM
Any ideas?
Anyone got any ideas as to what this rock is?
Sawing since '94
Bib, give this a try and see what you come up with. My guess would be its volcanic in nature. Maybe RHYOLITE (rye'-o-lite)
http://www.rockhounds.com/rockshop/rockkey/index.html#Using%20Key
Roxie
Google liver colored feldspar (mentioned in Jeff's rhyolite link).  The sunstone looks close to me.  From what I've been able to understand, the coloration comes from copper.
Say when
