SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Whatcha Sawin' 2021 ??  (Read 116016 times)
Offline Old Greenhorn
    • Woodsman Forest Products
Re: Whatcha Sawin' 2021 ??
« Reply #240 on: February 05, 2021, 06:05:57 PM »
FFOTS, yeah, um sure, c'mon up and play on my mill. It'll be fun!
 But first, you have to find it. ;D :D
Offline DPatton
    • D & S Sawmill Services
« Reply #241 on: February 05, 2021, 10:25:06 PM »
Our forecast says single digit highs and subzero lows all next week for me. The saw is going to stay parked at home.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #242 on: February 05, 2021, 10:28:43 PM »
Everything was going along just fine, and then............from the right side to the left side, something changed :D
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #243 on: February 05, 2021, 10:39:07 PM »
Nailed it.  It looks like your blade kept cutting flat with a tooth out of set.  Blades are the best metal detectors.
Offline DPatton
« Reply #244 on: February 05, 2021, 10:40:28 PM »
Danny, when you run that thru the planer the lines will run the other way :D :D ;D.
Offline WDH
« Reply #245 on: February 05, 2021, 10:43:25 PM »
 :D :D Exactly!  You can use a bandsaw blade as a metal detector, but never a planer :)
Offline firefighter ontheside
  • I like trees.
« Reply #246 on: February 05, 2021, 11:18:52 PM »
From right to left and from the nail on down.  Lol.
Don't think I wouldn't enjoy it OG.  I didn't get to go skiing this year, I am really needing some snow in my life.  Supposed to get 2" tomorrow.  Of course I'm at work...the only time I don't really enjoy snow.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Offline Patrick NC
  • I'm not new anymore, but still pretty green
« Reply #247 on: February 06, 2021, 06:14:15 AM »
:D :D Exactly!  You can use a bandsaw blade as a metal detector, but never a planer :).
My blades will even help lower backstops and loosen clamps! 🤣
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Offline olcowhand
  • I'm new- ish!
« Reply #248 on: February 06, 2021, 06:36:37 AM »
Everything was going along just fine, and then............from the right side to the left side, something changed :D.
Danny,
I find this pic fascinating, as it teaches me a little bit about "Speeds & Feeds". As most of you know, I don't (yet) own a sawmill- I use a CSM. Your pic tells me that (not sure how wide the piece is, but assuming it's in the 6" range) the band makes one full revolution for every ~3/4" of travel... That is humming right along. My CSM wouldn't surprise me to find the same tooth on the 32" bar making contact with the piece about every 1/8". So I can complete my calculations, how wide was your work piece- and was it Softwood or Hardwood?
DanG, I've got to get me a Bandsaw Mill!
Thanks.
Steve
Olcowhand's Workshop, LLC
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Offline longtime lurker
« Reply #249 on: February 06, 2021, 06:48:43 AM »
Playing truck drivers because neither of my haulage contractors likes dealing with them at that size.... about 9 tonne in the head end of the log and when you start shunting them over the side with a dozer its hard on the gear and things get broken. 20' x 50"... 2645 BF Doyle... butt log will go somewhere up around the 4000 BF mark.
They'll bring the weekly average back up anyway.
Offline nativewolf
« Reply #250 on: February 06, 2021, 07:10:55 AM »
Great log LL!  Question why leave them so long?  Is that being sawn for grade lumber or is it one of those tough to process Aussi Eucs that is better off as a rough long lumber?
Liking Walnut
Offline WDH
« Reply #251 on: February 06, 2021, 07:27:33 AM »
Olcow,
The board is about 12” wide.  The wood is older, natural southern yellow pine.
Offline nativewolf
« Reply #252 on: February 06, 2021, 07:30:29 AM »
Is that a Hino or ?
Liking Walnut
Offline Crossroads
  • let’s make some sawdust
    • K Bales Enterprises llc
« Reply #253 on: February 06, 2021, 10:40:33 AM »
Talk about a double edged sword, we hate to find nails in the wood we saw, but use nails to secure the wood we saw 🤔
Offline Patrick NC
« Reply #254 on: February 06, 2021, 02:17:47 PM »
Some big white oak logs that we are going to send off to get slabbed. The big one on my right will probably get quartersawn.
 For size reference, I’m 6’3” tall.
Offline WDH
« Reply #255 on: February 06, 2021, 08:15:17 PM »
DanG!
« Reply #256 on: February 06, 2021, 11:08:36 PM »
Neah I had an order for 20' gunbarrel straight 4 x 4's. Whole lot easier when you're carving them out of big stable old growth logs... no need to oversaw and edge just carve them off and feed them into the moulder the right way and they came out about as straight as you'd ever get over that length.
My truck is an ACCO... "day cab" International COE, about the same half bunk area as a Hino. It does a job I guess, really only there for my convenience.... deliveries, pick up short loads of logs, shift my own skidder around etc etc. Need to put a crane back on it by rights but truth is I've either got to upgrade to more axles or get away from trucks altogether. It's really convenient but it's expensive convenience too.
Whole heap of thoughts there about carts and horses and the need to upgrade the mill capacity rather than the support equipment but without better support equipment then more mill is futile, and capital outlay vs returns, time costs, core business vs essential support services and where you draw lines around vertical integration and... and... and. Thats a whole topic by itself yeah?
Offline Greyhound
« Reply #257 on: February 08, 2021, 07:42:09 PM »
DanG!
Awesome!!!  I love white oak, especially quarter sawing the big clear ones!
Offline Patrick NC
« Reply #258 on: February 08, 2021, 08:12:43 PM »
Another 500’ of cedar going out in the morning.
I started sawing cedar when I bought my first mill because it was easy to saw. It’s turning into a pretty good money maker now. I’m averaging 2000’ a month. I was just buying 1000’ of logs at a time, but I bought my first tractor trailer load this week. It sells as fast as I can get it off the mill. Yellow pine is selling good right now too.  Just not enough hours in a day to get it all done!
Offline btulloh
« Reply #259 on: February 08, 2021, 08:18:41 PM »
Any idea what that ERC is being used for?  Was there a lot of demand for it before you started supplying it or did the demand develop because you made it available. Just curious ‘cause it seems like a lot of demand for green rough sawn erc and it sounds like you’re the main source. Good for you no matter what.
HM126
SPACE AVAILABLE
