I had the Baker version for a few years. It's not a machine that I would want to use for production volume work.
My biggest problem was that it just wasn't robust enough for making 1000 - 2000 sq. ft of flooring at a time. Chip extraction was poor, and the feed rollers would get chips embedded in them and then slip, which then required us to force the boards through it.
I had to replace bearings on some of the feed rollers before the machine had even 300 hours on it,
Perhaps the Logosol is a stronger machine, but an older Weinig, Mattison, Woods, etc may provide you with better service.
