Dynamic Green Products Inc.
Author Topic: New UTV  (Read 1346 times)
Offline snowstorm
Re: New UTV
« Reply #20 on: January 09, 2021, 06:36:49 AM »
i dont see any way to control the temp with the inferno heater is there ?
Offline Walnut Beast
Re: New UTV
« Reply #21 on: January 09, 2021, 06:41:28 AM »
Snowstorm do you have vents with your heater
Offline snowstorm
Re: New UTV
« Reply #22 on: January 09, 2021, 11:27:35 AM »
there are lots of them.2 to defrost 3 in the dash and 2 down below. usually the fan is on low and the temp adjustment half or less. at 35 mph you will get a draft from the roof  and a few under dash foot well. i sealed some of it got to do a little more. i know there is a dust kit for a ranger. when i put the heater in i did the windshield wiper washer also. the hardest part of installing the heater is cutting the vent holes. they are marked where to cut
Offline farmfromkansas
Re: New UTV
« Reply #23 on: January 09, 2021, 01:42:55 PM »
The ad says it has a shut off valve, but there is no ball valve shown with the kit, so there must be some way to control the flow on the heater, but can not see anything.  Anyone out there with an Inferno heater?
Offline SwampDonkey
  • Large Tooth
Re: New UTV
« Reply #24 on: January 09, 2021, 03:01:26 PM »
Check Youtube.
Move'n on.
Offline snowstorm
Re: New UTV
« Reply #25 on: January 10, 2021, 08:39:30 AM »
looks like the shut off valve is for summer use. also it says they take there hot water from the oil cooler. maybe that works fine. i looked into after market heaters and decided against it. sometimes you are better off spending a little more
