Author Topic: What species of wood  (Read 719 times)
Offline Ed D
« on: January 08, 2021, 02:19:08 PM »
The pictures below are of a piece of tongue and groove flooring from an old farmhouse supposedly built in the 1840's in northeast Ohio.
The flooring is 1-3/16 thick and looks like it was planed on one side.  I thought at first it might be yellow poplar, however is seems denser that current yellow poplar I am familiar with.
My next thoughts were either chestnut or sassafras.  There is no "root beer" smell on a fresh cut.
Any thoughts out there?
Thanks for any suggestion!
Ed
Offline SwampDonkey
  • Large Tooth
Re: What species of wood
« Reply #1 on: January 08, 2021, 03:57:00 PM »
Birch I think. Rays are barely visible, distinct pores but small, diffuse. I rule out maple because the rays are not so distinct as they should be. Maybe it is just out of focus.
Sometimes planing involved glass scrapers. My grandparents built a house in the 40's with hard maple floor through out.  All finished with glass scrapers.
chestnut has large earlywood pores, minute rays.
Birch
Different light
maple
No amount of belief makes something a fact. James Randi
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: January 08, 2021, 06:00:53 PM »
   Looks like some ash I have sawed.
Offline Ed D
« Reply #3 on: January 08, 2021, 07:20:21 PM »
Thank you SD and WV for your comments and observations!
SD, below is that same piece highlighted with water.  Does that help with the "rays"?
Thank you SD for the samples you posted.
Also this wood throughout this old house is very dark - general overall color not lite colored like hard maple, rather the color of chestnut.  It seems to be however as dense as maple.
The flooring could have indeed been scraped, because it does not have a even surface like planing.  It has however been walked on for a few years. :D
Thank you for your input.
Ed
Offline btulloh
« Reply #4 on: January 08, 2021, 08:12:54 PM »
Birch?
HM126
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: January 08, 2021, 08:48:43 PM »
The terminal parenchyma at the end of the growth rings indicates yellow poplar to me.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Ed D
« Reply #6 on: January 09, 2021, 09:57:11 AM »
Thank you Btulloh and WDH for your input!
Below is a scanned photo of the same piece.
Also there is a fair amount of Yellow Birch that grows in the area this old home was built in.
Thanks to all for your thoughts.
Ed
Offline Don P
    • Calculator Index
« Reply #7 on: January 09, 2021, 10:13:21 AM »
Throw it through the planer and take a heavy bite. If its poplar the green will still be under there in fresh wood. Danny is the pro but I'm having trouble seeing poplar there.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline SwampDonkey
  • Large Tooth
« Reply #8 on: January 09, 2021, 03:16:56 PM »
Lots of yellow birch in flooring. I have trouble thinking it is anything else. :D
Offline WDH
« Reply #9 on: January 10, 2021, 08:29:54 AM »
 popcorn_smiley
Offline Ed D
« Reply #10 on: January 11, 2021, 06:12:30 PM »
I sorry it took so long to get back to Ya'll.  I hope WD did not suffer any indigestion from all that popcorn looking for a speedy reply. :D
Don, in the photograph below, I cut the end of the piece on the table saw (planer unavailable).  I saw no green in this piece or in any others that we have cut.  All fresh cut pieces have that even yellow tone to them (except that original piece that I supposed was wane) and where it was exposed to the atmosphere, it has turned to the light brown as shown.  The darkened streaks in this sample that was cut on the table saw, looks like stain permeation were created in fact by a fine file that I tried to smooth the cut with.
The next two pictures are scanned while dampened.  They are both of the same piece, just one is zoomed in.
Please, your thoughts?
Appreciate your input!
Ed
Offline Don P
    • Calculator Index
« Reply #11 on: January 11, 2021, 10:47:28 PM »
Dang I hate that, its sure looking to me like Danny is right again  :D
Guess I owe him a chunk of butternut for his popcorn.
Offline SwampDonkey
  • Large Tooth
« Reply #12 on: January 12, 2021, 06:41:23 PM »
Not birch in those latest pics. ;D As to poplar, can't help ya.....not aspen right? :D
Offline kantuckid
« Reply #13 on: January 16, 2021, 09:31:44 AM »
My highly specialized, scientific, old wood tester is made by the Germans and called Boker Tree brand.
Maybe not classroom, lab true to form, but it relates to cutting on wood that came from a tree I knew when it was alive and often wearing it's leaves and bark.
When reclaiming wood it was always the first real look beyond the grime when nothing seemed easily apparent.
 Birch is harder than poplar and the "Boker Test" would have solved that aspect instantly.
Wood Species Identification
Started by ForestMan on Sawmills and Milling
Last post March 12, 2010, 10:03:56 AM
by OneWithWood
Help Needed Re:Wood Species
Started by campy on Sawmills and Milling
Last post October 23, 2010, 06:30:28 PM
by campy
Wood Species for TF Porch
Started by snowmountain on Timber Framing/Log construction
Last post March 29, 2021, 05:31:51 PM
by Don P
Guess This Wood Species II
Started by TexasTimbers on General Woodworking
Last post November 14, 2007, 06:28:17 AM
by SwampDonkey
