Dynamic Green Products Inc.
Author Topic: Edgers  (Read 1237 times)
Offline Redhorseshoe
Edgers
« on: January 08, 2021, 10:08:47 PM »
I hate to add another "this or that" thread to the forum but here I go anyway. . .
I'm going to get an edger.  I'm looking at the Riehl, and the eg200.  There is a significant price difference between the two, about $4,500.  I've been so happy with Woodmizer and their customer service I'm inclined to spend more money with them, plus Woodmizer Oregon is about two hours from me which really helps with parts and service.  I can't find much info on the Riehl but what I've found is people are happy with them too.  Also, just to convolute this even more, I've looked a little at the eg100 and like the price tag but it doesn't really seem like the same caliber of machine as the others.  What do you all think about these?  Pros, cons, likes, and dislikes?
Offline Southside
    • White Oak Meadows
Re: Edgers
« Reply #1 on: January 08, 2021, 11:39:44 PM »
Well lets see, on the WM side of things I own a Super 70, an LT35 HD, the 200 kiln, a 250 sharpener and it's sister setter - what's that $150K worth of WM equipment?  My edger is a Riehl - and that was by choice.  Darin makes great equipment and is excellent to deal with, lot more value there than what the price reflects.
White Oak Meadows
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
Re: Edgers
« Reply #2 on: January 08, 2021, 11:58:21 PM »
I was going to get the riehl but I came across a used eg 200 diesel with 112 hours on it that was way too good of a deal to pass on.
I'm happy with my woodmizer. I got the split blades for it which makes blade changes way easier.
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Offline 51cub
Re: Edgers
« Reply #3 on: January 09, 2021, 05:52:03 AM »
If memory serves, @Bruno of NH  is a Riehl and said pretty much the same as Southside said about his
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
If nothing else I'm always a good last resort or the guy to hold up as a bad example
Online Bruno of NH
Re: Edgers
« Reply #4 on: January 09, 2021, 07:11:11 AM »
I have a Riehl
It's a well built unit.
I had an issue but it has been taken care of and works great .
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline moodnacreek
  • Sawin by the notches
Re: Edgers
« Reply #5 on: January 09, 2021, 08:05:22 AM »
The Riehl edger is too small for me and so is the old Chase I completely rebuilt. I looked at the Riehl at the Bloomsberg show a few years ago and I thought it was well made and reasonably priced for those who do alot of softwood boards. Right now I have a large [beyond my capability] order for 3x6 locust. It is a standing order, do as much as I can. The 3" flitches will be going through my edger with the feed in gear 1.
Offline tacks Y
Re: Edgers
« Reply #6 on: January 09, 2021, 08:30:13 AM »
So what are the 3 x 6s used for?
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Edgers
« Reply #7 on: January 09, 2021, 09:16:47 AM »
Ive got a Baker and love it.  You may consider them, also.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline moodnacreek
Re: Edgers
« Reply #8 on: January 09, 2021, 07:36:41 PM »
I didn't ask. The guy is a regular buyer of locust, normally 2x6 2x8 x 8'. He builds trails through the woods or over swamps, board walks so the hikers don't get there feet wet, with your money [grant money] Don't spread this around.
Offline moodnacreek
Re: Edgers
« Reply #9 on: January 09, 2021, 07:46:46 PM »
The band mill companion edgers I have seen really turn me off because they have 'sides' on the infeed table. What in the world where the makers thinking .  I pile up flitch boards on a steel top table that is a scissors lift. From there I slide them on the edger. With these edger you would have to work with these sides. Also those with belt feeds scare me from my experience with belt conveyers and belt tracking problems.
Re: Edgers
« Reply #10 on: January 09, 2021, 07:57:57 PM »
I bring whole pallets up and put the boards on a roller table and push it in the edger.
There may be some belt fed edgers with tracking issues, I've heard of some, but Baker isn't one of them.  It is almost as accurate as my Straight Line Rip saw and the tracking is rock solid, I've only had got make one or two adjustments since we've had it.
YellowHammerisms:
Offline longtime lurker
Re: Edgers
« Reply #11 on: January 10, 2021, 05:36:59 AM »
X2.
I'm looking for about what you are I suspect... open one side, linebar the other, built to saw large volumes of hard stuff at speed.
And a bull edger as well, big one.... 2 Arbors to keep the kerf down, 8" deep cut, wide enough for 2 gangs at once (space my collars so I've got 2" one side and 1" the other for example) , and I need a linebar infeed on that too.
Ideally of course I want it all together...  Gangs and 3 shifting saws though those are probably out of my budget.
Have to come from your side the puddle I expect... not much available here and no-one with one will part with it. There's a big Salem for sale opposite corner of the country is the only one on the market and he wants 140k for it...  add the freight to get it home and call it $110k USD, too much for something you'd pick up over there for not much + paint and near enough the same in freight.
Glad to hear I'm not the only one who bites off moren he can chew!
Offline stavebuyer
Re: Edgers
« Reply #12 on: January 10, 2021, 06:04:25 AM »
The EG 200 is a solid bullet proof and simple machine but has a few downsides
1.Width of the the flitch it would pass is smaller than what you can saw on the "regular" LT40 platform.
2. Blades are a pain to swap unless you switch to after market split blades
3. 8/4 plus thick stock with realistic added thickness is a stretch for the machine in thick stock.
I have not used a Riehl. I had a Cooks which addressed the Wood-mizer shortcomings at a cost savings. It is belt feed and I did have to replace a feed belt we tore with short a edging strip getting hung. No issues tracking it and hydraulic speed adjust really shines when you go to 8-12/4 slabs.
Re: Edgers
« Reply #13 on: January 10, 2021, 12:23:57 PM »
Ive not run an locust through mine, but Baker put an upgraded 20 hp 3 phase on mine, did a custom design on the infeed and outfeed, and the agreement was that it had to cut full 3 inch boards, straight, and at a high production level speed (for me) or I wouldnt buy it.  We use full 12/4 stock and make mantles and leg stock out of them, so I need to be able to rip using 2 blades at a time, like a gang saw.
So when we went to Baker to pick up the edger, they had it waiting for us on the factory floor, with a crowd standing around.  On the pallet next to it was a huge 3 inch thick, 18 inch wide, long, mega piece of oak.  They fired up the edger, set the hydraulic belt feed for full speed, which to me was stupid fast, and several guys had to struggle to lift the hunk of wood on the infeed.  The foreman said Let it go and they let it go.  Everybody had a smile on their faces like the old redneck joke of Hey yall, watch this.  I swear the lights dimmed a little as the blades bit into it, and the pieces shot out the back on the conveyor, through the spit roller, and down onto a pallet with a boom.  It was one of the coolest and most memorable demonstrations Ive seen.  We put a straight edge on the cut and it was almost perfect, maybe 1/16 off over 8 feet.
We also ran some badly cupped, hard as a rock, kiln dried 4/4 white oak through it, as kiln dried boards with cup and crown are notoriously difficult to feed straight on any edger, and they came out straight, also.
I just asked Who do I pay?
YellowHammerisms:
Offline moodnacreek
Re: Edgers
« Reply #14 on: January 11, 2021, 08:07:45 AM »
You can't ask for more than that.
Offline moodnacreek
Re: Edgers
« Reply #15 on: January 11, 2021, 07:57:20 PM »
I am surprised some machine shop doesn't make an edger kit for the do it yourselfer if there are any left.  I know how to go about building one but that's because I have rebuilt 2 machines. But for the handy guy who can cut and weld steel, if he had a 'center section' to start with he cold make the rest. And if that center section, that would be the mandrel with fixed and shifting collars, was built heavy it could be a real machine. 4 feed rolls made with sprockets all chained together and driven off the mandrel through a riding lawn mower transmission works great. Dead rolls and press rolls from well casing . I bet a lot of guys have half this stuff out behind the barn.
Re: Edgers
« Reply #16 on: January 16, 2021, 09:53:23 PM »
Thanks for all the responses.  I ended up ordering a Riehl.  It won't be here until April or May but I'm feeling good about my decision and am looking forward to putting it to work.
Are belt fed edgers better than rollers edgers?
Started by cnelson1 on Sawmills and Milling
Last post January 16, 2011, 05:51:11 PM
by Kansas
Edgers
Started by shopteacher on Sawmills and Milling
Last post May 12, 2003, 08:58:10 PM
by Linda
Edgers
Started by BigZ La on Sawmills and Milling
Last post September 20, 2016, 08:04:27 PM
by 4x4American
Edgers...Do they pay to have?
Started by flip on Sawmills and Milling
Last post October 19, 2005, 02:16:10 PM
by flip
