Dynamic Green Products Inc.
Author Topic: LT70 diesel regen  (Read 470 times)
Offline Bindian
  • Gender: Female
LT70 diesel regen
« on: January 09, 2021, 02:38:44 PM »
Regen pops up at the most inconvenient times.  First time I had the mill in the part doing mx on it.  This time I was fixing to saw a Red Oak.  Can I saw logs while in regen?  I tried calling Woodmizer and my dealer and it seems everyone goes to lunch at the same time.
             hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel.
My Hero is Johnny Jett
Online terrifictimbersllc
    • Terrific Timbers LLC
Re: LT70 diesel regen
« Reply #1 on: January 09, 2021, 03:32:25 PM »
My 2019 tier 4 yanmar 55 hp does a "running regen", a red icon  comes on on the display and you can smell the hot exhaust, yes can run the mill as usual during that time.    There is also a stationary regen which i have never seen  yet in 569 hours which if it makes you start that 20 min process you cant saw during that.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #2 on: January 09, 2021, 06:27:10 PM »
When it does that. do sparks come out of the muffler?
A&P saw Mill LLC.
License NH softwood grader.
« Reply #3 on: January 09, 2021, 06:32:16 PM »
Not that I have seen. Next time I saw at night will look for it.  :laugh:
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #4 on: January 09, 2021, 06:48:04 PM »
No, I've never seen sparks or anything else come out of the muffler on regen.  Just a smell.  Nothing more.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline Fern Wood
« Reply #5 on: January 09, 2021, 07:54:51 PM »
Mine usually wants to regen when I am wanting to quit for the day. Doesnt cycle thru unless the blade is engaged so I take the blade off and let it do its thing. I called wood mizer and asked if there was a function that would bring the engine to full throttle without engaging the blade . No was their answer and I told them there should be.
Offline Southside
    • White Oak Meadows
« Reply #6 on: January 09, 2021, 08:26:48 PM »
You could try un coupling the auto clutch motor at the connector, then the band would not be turning.
White Oak Meadows
Offline Bindian
  • Gender: Female
« Reply #7 on: January 09, 2021, 11:13:59 PM »
Did I read somewhere not to run the mill with the blade off.  I was ticked off today and I needed to load and turn a 20 foot 4 log and the blade was just too close to log movement while in regen.  So I came in and read some emails.
Only regens I have seen is full load needed.  So I turn on the clutch and spool up the rpm.
Also, title typo error.  I have a LT40, not a LT70
hugs,  Brandi
« Reply #8 on: January 09, 2021, 11:33:44 PM »
I read the engine manual and as I understand it, there are several regen cycles that can be completed.
If I want to shut down for the day in a regen mode, I just bring the engine to idle for a short time while I clean up the days mess, let everything cool down, and turn the engine off.
The next morning, as soon as the engine warms back up, the regen mode automatically restarts and I finish it then.
Ive been doing it this way for 18 months and Ive had no problems.
Ive been doing it this way with my Tier 4 New Holland for 5 years and no problems, either.
YellowHammerisms:
Offline Bindian
  • Gender: Female
« Reply #9 on: January 10, 2021, 12:43:22 AM »
Thanks YH.  I will keep that in mind next time.
hugs,  Brandi
Offline Fern Wood
« Reply #10 on: January 10, 2021, 08:41:24 AM »
Thanks Yellow Hammer. Probably best way to do it.
building for lt70 diesel
Started by tom mccann on Sawmills and Milling
Last post November 08, 2008, 07:39:49 AM
by bandmiller2
Lose of oil pressure LT70 with 62cat diesel
Started by Beavertooth on Sawmills and Milling
Last post July 14, 2015, 05:10:00 PM
by Dave Shepard
Getting Balsam Fir Regen ??
Started by g_man on Ask The Forester
Last post April 01, 2018, 02:19:44 PM
by Ken
Ferns and Regen
Last post February 08, 2013, 05:35:19 PM
by g_man
