We have contest winners!
Mr.Green and 1 Guest are viewing this topic.
My advice would be don't use fiberglass insulation. Use polyiso instead.
Fiberglass will absorb moisture when the kiln leaks, I say when because like a tire eventually it will. Polyiso is moisture resistant.
Howdy Neighbor! I'm about an hour and a half east of you.Several comments.First and foremost - most consumer and commercial dehumidification units are not suitable for a wood kiln environment. They do not have a high enough temperature threshold and they are not corrosive resistant. Many of them shut off at 104F, and most DH kiln drying is done between 90 - 120F, so that's a problem.I'd highly recommend a Nyle L200 for the size loads that you want to dry. Source your fans from them as well because they are designed for a kiln environment.Second - Stan's advice is spot on. Don't use fiberglass insulation; you will regret it. DH kiln temps typically vary between 90F - 160F, and there will be a lot of structural movement over that span of temps. That means leaks into the walls and the fiberglass will not live well.Third - you will want two man doors on the ends - one on each side of the lumber stacks so that you can visually check status and take MC% readings as required.Fourth - insulate the floor or it will be a big heat sink. You will see a variance in the drying conditions between the lumber at the bottom of your stacks versus the lumber at the top.Fifth, there are times that you need to vent the kiln. Are you planning to run some duct work through the walls or ceiling?Best of success to you.Scott
Quote from: scsmith42 on January 12, 2021, 05:07:21 PMHowdy Neighbor! I'm about an hour and a half east of you.Several comments.First and foremost - most consumer and commercial dehumidification units are not suitable for a wood kiln environment. They do not have a high enough temperature threshold and they are not corrosive resistant. Many of them shut off at 104F, and most DH kiln drying is done between 90 - 120F, so that's a problem.I'd highly recommend a Nyle L200 for the size loads that you want to dry. Source your fans from them as well because they are designed for a kiln environment.Second - Stan's advice is spot on. Don't use fiberglass insulation; you will regret it. DH kiln temps typically vary between 90F - 160F, and there will be a lot of structural movement over that span of temps. That means leaks into the walls and the fiberglass will not live well.Third - you will want two man doors on the ends - one on each side of the lumber stacks so that you can visually check status and take MC% readings as required.Fourth - insulate the floor or it will be a big heat sink. You will see a variance in the drying conditions between the lumber at the bottom of your stacks versus the lumber at the top.Fifth, there are times that you need to vent the kiln. Are you planning to run some duct work through the walls or ceiling?Best of success to you.ScottThanks for the advice! I will seriously consider the Nyle products. I plan on having at least 1 Man Door in one of the barn doors and possibly one door at one end of the kiln. 2 of the walls are built up against the brick walls in the corner so I cant add a door on one of the ends. My plan was to stack some foam insulation boards on the floor, removable during loading / unloading if necessary. I will also consider foam boards for the walls. Is the issue with fiberglass insulation really the humidity from the inside? I am trying to not brake the bank on this, but if it is necessary I will consider different insulation. I am planning on running a vent, not sure where yet, but I may be able to run it directly outside.
I'd skip the door in a door plan and just put two doors on the exposed end wall. The problem with the door in a door is that it severely weakens the larger door.The temp foam on the floor will help, especially if you put your lumber on pallets and then fill in around the pallet with the foam boards. This will also serve to baffle the ends of the pallets; forcing the air through the lumber stacks instead.During the initial portions of the kiln drying process it will be extremely humid inside, and moisture will escape and condense.Re the vents - you need two - one from the suction side of the fans and one on the pressure side.
I have a drain near by that will work great for getting rid of the water. If I was to try to use a commercial dehumidifier for a while, can they be ducted so they are not in the heat of the kiln? If not, is there any harm in only running the kiln as hot as the dehumidifier will allow and not use the dehumidifier during the sterilizing phase? I am not necessarily trying to dry slabs as fast as possible right now. This could change in the future, but for now I can be patient if necessary. Thanks for all of the input, greatly appreciated!
Started by caveman on Drying and Processing
Started by ozarkgem on Drying and Processing
Started by D6c on Drying and Processing
Started by Crookedkut on Drying and Processing
