The ring of bolts that secure the tc to the flywheel housing need to be removed. If you do this, the torque has a replaceable bushing on the nose that serves as a pilot bearing into flywheel. Make sure the pilot does not have wear this will cause premature failure.There is a 16 bolt fiber gear and a 32 bolt version ring gear.
