BLUECREEPER Poster Award #3!
The biggest issues they had several years ago was some bad batches of the torsion axles that had to be replaced
Very nice! Should be a great mulching unit, what head will you put on that? Do you have any issues with rock? I love that screen, hope the cameras are easy to replace or fix the lenses. I'd love to have something in our skidsteer , one of my big gripes.
Quote from: nativewolf on February 11, 2021, 03:05:37 PMVery nice! Should be a great mulching unit, what head will you put on that? Do you have any issues with rock? I love that screen, hope the cameras are easy to replace or fix the lenses. I'd love to have something in our skidsteer , one of my big gripes.Probably leaning toward a Prinoth head that takes varies teeth. Cutter teeth that you can sharpen and various carbides for rocky soil and different conditions. You can run both on the head and some do. A friend that bought two PrimeTech dedicated mulchers said I think your going to regret buying the Prinoth. So I’m deciding on FAE sonic head also. It’s got some new type of electronics that work with your machine like a transmission on the head when it gets loaded. He said it works awesome. The Dennis Cimaf company has been sold after he passed and bought a couple times since and I heard the quality is not even close to what it was. You definitely want to make a good decision on these heads of this caliber range when there 36-42k
ASV's float when others don't. They are more maintenance for sure but they flat outperform other track u/c's imo. I've spent a fair amount of seat time in both. The old models like the 4810 were known for losing tracks, but I never had an issue with the newer ones.
Snow is it’s own beast to operate in with a light crawler. Long ago but not too far away I worked in a sawmill that used a nearly new 1010 Deere crawler/loader with forks as a yard machine. Load the deck with logs and move packs of lumber out to the yard. The mill was on a side hill with the log deck at ground level and the tail section up about 10’ in the air. Backing away from the mill with a pack of lumber, the back of the crawler would ride up on the snow. I’d only be able to back up maybe the length of the machine before I would have to go ahead a bit to bring it back down. Jockey around like that 3-4 times before I could get far enough away from the mill to turn and travel forward. Tossed the slabs down into a KB-6 dump truck. Even with triple side chains on, that was a job to get over to the slab pile and back.
Started by chet on Chainsaws
Started by Bobus2003 on Forestry and Logging
Started by RPowers on Sawmills and Milling
Started by labradorguy on Forestry and Logging
