BLUECREEPER Poster Award #3!
Going back through the comments it seems like nearly everyone said grapple with a winch. But if you already have your mind on a cable have at it. Been there done that and it just flat isn't as productive, especially on smaller pieces where getting hooked up and turned back around is more important than getting that extra log per hitch/turn. Either one will outproduce 15k per day, or at least can I should say, not having seen the jobs. 15k was a pretty normal out west here for a cable skidder, on decent ground and wood they could do more of course.
Quote from: quilbilly on February 14, 2021, 10:49:14 PMGoing back through the comments it seems like nearly everyone said grapple with a winch. But if you already have your mind on a cable have at it. Been there done that and it just flat isn't as productive, especially on smaller pieces where getting hooked up and turned back around is more important than getting that extra log per hitch/turn. Either one will outproduce 15k per day, or at least can I should say, not having seen the jobs. 15k was a pretty normal out west here for a cable skidder, on decent ground and wood they could do more of course. Agreed most are saying grapple, most are also saying to use the dozer to bunch logs in bad terrain. I have 2 concerns that you may be able to clear up. 1. Can I still hit 15k per day average with a 3 man crew while also having to bunch 30% of the logs with the dozer?2. I’m also concerned with the steep terrain using a grapple skidder vs cable. Buying the same sized machine a cable skidder has the advantage of getting through a steep spot while pulling a larger load. I don’t want to be limited with a grapple to 1-2 trees and hurt footage or end up dumping a log at the hill every time to keep the skidder moving. The tract we just finished was 20 acres, it was split by a steep ravine that we put a bridge in to cross but still had a very steep 60’ section on both sides. Dozer had to drop the logs and winch them every time. Grapple skidder would have been very limited on half of this job of the dozer would have been working to bunch the logs. I’m gonna talk to a few guys about renting a skidder for a week or two and see how it works. My next tract is 40 acres and all down hill skids so I’m sure a grapple will shine.Also I didn’t say it but we have a loader and bucksaw at the landing.
Started by sticks on Forestry and Logging
Started by killamplanes on Forestry and Logging
Started by NH Forester on Wanted
