BLUECREEPER Poster Award #3!
I know this may be counterintuitive to most, but I am curious what small rigs people use out there. As someone who does forestry and logging on my own land, sometimes I like to use the smallest thing possible to get the job done, especially in hard to reach areas and places I don't want to do a lot of damage.I will go first My smallest rig (if you exclude an ATV and a log arch, with a portable capstain winch) is a Gehl RT105, with forks that have a custom fabricated grapple arm and a 12K lb electric winch, with a pull behind log arch that I also custom fabricated. I had to use forks with my own custom grapple in order to keep the weight down since the RT105 only has about 1,500 to 2,000 lbs of usable lift (tipping is 3000 lbs). I thought I could make a much beefier log arch at a fraction of the price using steel I already had. It is made of 2" steel square tube that has 1/4" thick walls. I used 1/4" steel plate to gusset the arch, and I put on forklift tires that have a double rim (the tires and hubs are usually the weak points on the commercial arches one can buy). The hitch on the arch is a rotating one so it won't flip me over or bend the tubing if I get in trouble. The grapple arm and winch are removable so I am able to go back to using the forks alone whenever I need to. I am able to skid one full hardwood tree in about the 20-25" range. I put the butt log in the arch and carry the top logs on the forks. It works pretty well...the arch can carry up to about a 38" tree, but I haven't pushed it past a 10' long 30" red oak before. The best part of this rig is that the width is 48", so I can go anywhere my four wheelers can go to get to the trees (I usually harvest wind blown trees).Please share what you have/use! One of these days I will get a video up on my YT channel using this setup once our polar vortex goes back up north...in the meantime here are some pictures. (Image hidden from quote, click to view.) (Image hidden from quote, click to view.) (Image hidden from quote, click to view.)
A log arch is your best friend for tough to access areas. You can pull them with just about anything, if you use an ATV get a big one (over 600 cc if possible) and don't get something with a CVT transmission, you will want all the engine braking you can get. Also, the rotating hitch is a must lest you be flipped over when your arch decides to tip. Pine trees are lightweight so you shouldn't have many issues. Another thing about a log arch is you can use it with a winch to pull logs down from high places, or pull them up from low places...pull the arch with the winch to an area where you can hook up to your tow vehicle and you are good to go. I have a lot of hills and I typically just park skid steer at the bottom of a hillside, winch the arch up to the log I need using a portable winch, then use the portable winch or the one on my skidsteer to pull the log down the hill with the arch.Hope that helps!
As long as you have engine braking my polaris Ace 570 doesn't and it is a pain going downhill. My Hondas on the other hand have amazing transmissions You may run circles around my Pioneer 800, but you may remember how the tortoise and the hare story ends jk , but seriously my Hondas are about as bullet proof as you can get from a reliability standpoint.
What is the age limit ?
Started by treefarmer87 on Forestry and Logging
Started by Bodger on Sawmills and Milling
Started by ozarkgem on Forestry and Logging
Started by RandyL on Timber Framing/Log construction
