Dynamic Green Products Inc.
Author Topic: 540e starting issue  (Read 419 times)
Offline MichaelLatorra
540e starting issue
« on: February 16, 2021, 01:50:50 PM »
I have a 1992 540E that I'm having trouble starting.   Fuel is not gelled, starter just rebuilt, batteries good, Fuses good, park brake switch on shifter is good.  The machine fires but something tells it to shut down immediately.  Does anyone know if something in the monitor module tells this machine to shut down if a permissive isn't met?  Looking for a starting point.....Thanks Mike
Offline mike_belben
  • Pulp Friction
Re: 540e starting issue
« Reply #1 on: February 16, 2021, 04:58:37 PM »
Got an oil pressure switch in the head maybe?
Revelation 3:20
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #2 on: February 16, 2021, 06:04:35 PM »
Check power to the pump first to make sure your not loosing power somewhere after start up if that’s all good take the return line off the pump if it runs with the return line off it’s got a restriction in the return line. They won’t run with the return line plugged
Offline BargeMonkey
« Reply #3 on: February 16, 2021, 07:11:34 PM »
4-276T or 6059T engine ? Like mainelogger said check the return, ive never had an E but had a 544G of the same vintage. 12v to the pump ? Where i would start.
« Reply #4 on: February 17, 2021, 05:19:57 AM »
4045t engine.   Thanks for all the help, ill see what happens.
Offline teakwood
  • Switzerland
« Reply #5 on: February 17, 2021, 07:27:32 AM »
My excavator did this and it was a faulty fuel cut off solenoid, ( they're a safety feature so the engine can be shut down at any circumstance) but i don't know if your engine has this feature
Offline mike_belben
  • Pulp Friction
« Reply #6 on: February 18, 2021, 04:58:59 AM »
Has it been parked quite a while?  Those stanadyne rotary pumps sieze up the pumping element inside frequently from sitting.
 pull the feed line into the injection pump and crank to prove the transfer and filtration.  Verify 12v to the shutoff and an audible click.  Now pull a discharge line off the pump and crank.  If no output, pull the pump and send it out.  I think the timing cover has to come off to free the pump shaft from the gear.
Revelation 3:20
Offline mike_belben
  • Pulp Friction
« Reply #7 on: February 18, 2021, 05:02:23 AM »
If by fires you mean it hits on one two holes, i would crack all the injection line ferrules and try to bleed, verify each is squirting.
Revelation 3:20
Offline BargeMonkey
« Reply #8 on: February 18, 2021, 05:50:58 AM »
And you want to be SMOOTH when you pull that gear 😆 And the best part is the 200 timing tool youve got to have to remount the pump without guess work, even the little Allen key you get says Stanadyne... like its make of gold. Not a job I advice a backyard mechanic to try.
Offline mike_belben
  • Pulp Friction
« Reply #9 on: February 18, 2021, 07:06:12 AM »
When i am king, i will decree that all manufacturers must design their junk for the backyard mechanic or face relentless tax audits.
;D
Revelation 3:20
Offline BargeMonkey
« Reply #10 on: February 18, 2021, 07:31:08 AM »
Mike I would rather be elbow deep in a 16-645 EMD than work on a small 4 stroke 😆 I think this guys issues could be ruled out pretty quickly, a non electronic 4045 is almost detroit simple.
MS 391 Starting Issue
Started by Radar67 on Chainsaws
Last post July 04, 2014, 05:40:30 PM
by Ianab
Starting Issue On A 300 Ford Six Cylinder
Started by Autocar on General Board
Last post February 23, 2017, 01:09:52 PM
by Ox
95 John Deere 540E Skidder
Started by barniescamp on Forestry and Logging
Last post December 24, 2009, 03:15:19 PM
by barniescamp
GFI issue
Started by Raider Bill on General Board
Last post May 24, 2017, 02:51:53 PM
by Raider Bill
