Author Topic: Species id  (Read 300 times)
Offline DonW
Species id
« on: February 27, 2021, 07:54:27 PM »
E
 the knot configuration exposed on the end grain gives an indication of species. What species is this?
Online Tacotodd
  • To learn and help
Re: Species id
« Reply #1 on: February 27, 2021, 08:03:42 PM »
Probably need a fresh view. 🤷‍♂️
Trying harder everyday.
Offline DonW
Re: Species id
« Reply #2 on: February 27, 2021, 08:13:37 PM »
The view is pretty clear of the one end grain, the knots form a kind of star indicating a growth with branches opposing each other rather than a staggered growth. Is that a characteristic of Spruce or another evergreen?
Offline btulloh
Re: Species id
« Reply #3 on: February 27, 2021, 08:41:07 PM »
It is some kind of conifer.  That is a whorl like a white pine, but Im not familiar enough with species in your area. What conifer in your region has branches in whorls like that. More than one type?
HM126
Offline DonW
Re: Species id
« Reply #4 on: February 27, 2021, 09:05:33 PM »
Neither am I being new to this area. There are Spruce, Ponderosa, "Pine", Pinion and Juniper but these last are identifiable enough. Then it's not the case that the opposing branches is an identifying feature? Thought I was on to some way of knowing the species tree used to build these old log structures.
Offline btulloh
Re: Species id
« Reply #5 on: February 27, 2021, 09:10:57 PM »
More than one species does that. I dont know how many different ones out there the do it though.  I guess well need a real expert like WDH to check in.
They look like the would be from smallish branches, so that may narrow it down.
HM126
Offline btulloh
Re: Species id
« Reply #6 on: February 28, 2021, 12:06:48 PM »
Well I thought Danny and/or caveman might see this and chime in, but I guess its time for the Bat Signal. @WDH  @caveman
HM126
Offline SwampDonkey
  • Large Tooth
Re: Species id
« Reply #7 on: February 28, 2021, 02:00:09 PM »
If it were here in New Brunswick I would say spruce. I've never seen a camp made of fir or pine logs. Log homes these days can be made of red pine logs, but that is modern times. My grandfather had many camps in the woods and I have been to all them, plus a number of fishing camps on rivers. They were all spruce, and mostly red or black spruce, but white spruce is also possible. Out your way, spruce or pine is probably likely.
Back east here, I have only seen one cabin made of northern white cedar up this way, but that was square timber, not logs. And branches are alternate, not whorled on those.
You going to build one? ;D
No amount of belief makes something a fact. James Randi
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Species id
« Reply #8 on: February 28, 2021, 06:38:07 PM »
It is very likely lodgepole pine, Pinus contorta.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline DonW
Re: Species id
« Reply #9 on: February 28, 2021, 07:42:27 PM »
I'm going to fix some up replacing bad sections where it's needed. Getting close on the right wood is where I chose to start.
It's one of the trees growing in the area so could be that's what's been used. Very helpful.
Pioneer species vs. Intolerant species ?
Started by BrandonTN on Ask The Forester
Last post December 05, 2019, 09:09:46 PM
by wisconsitom
Uses for odd species?
Started by Okrafarmer on Sawmills and Milling
Last post August 26, 2010, 08:06:50 AM
by bandmiller2
What Species Is This?
Started by martyinmi on Ask The Forester
Last post July 12, 2012, 03:42:49 AM
by SwampDonkey
What species of fir is this?
Started by lostagain on Tree, Plant and Wood I.D.
Last post October 02, 2015, 06:20:10 PM
by Magicman
