So you use both machines in the woods logging I guess?How big are your trees logs etc?Any hardwood ? Winter and summer ? Or both ? Any pics ? Quebecnewf
Having both a 16k lb excavator and a dozer, and spent a little time in the woods with both, I would say your better off with a little dozer with a winch in the woods. The excavator is great for making trails and moving the brush and whatnot, but when it comes to hooking onto a tree and getting it somewhere, especially when you say it's pretty crowded in your woods, a dozer/winch combo will be much more effective. Swinging the excavator around gets tricky in tight woods, and it's just easier to plow over trees if necessary with the dozer and winch anything in any direction. Plus, you get a good hook of logs and chances are you can still travel a bit faster with the dozer than with the excavator. Plus steering clutches are quite a bit cheaper than final drives...
My excavator is mid-sized, about 16,000lbs. I was lucky enough to stumble across this rather locally. 1990's, so it's not very compact for it's weight - but does make it easier to work on. Came with a hydraulic thumb and 24" tracks. You can see the rocks I deal with in this pic. Size and power have been perfect for my application. The counterweight swings well over the tracks, so being careful when swinging I've had to learn the hard way. This cost me about $22k. Hour meter shows 4,000+ hrs, but doesn't work. Probably more like 6-8,000 hrs. (Image hidden from quote, click to view.)
Quote from: Mattjohndeere2 on March 12, 2021, 11:45:39 PMHaving both a 16k lb excavator and a dozer, and spent a little time in the woods with both, I would say your better off with a little dozer with a winch in the woods. The excavator is great for making trails and moving the brush and whatnot, but when it comes to hooking onto a tree and getting it somewhere, especially when you say it's pretty crowded in your woods, a dozer/winch combo will be much more effective. Swinging the excavator around gets tricky in tight woods, and it's just easier to plow over trees if necessary with the dozer and winch anything in any direction. Plus, you get a good hook of logs and chances are you can still travel a bit faster with the dozer than with the excavator. Plus steering clutches are quite a bit cheaper than final drives...Good recommendation but maybe he just needs to get both a excavator and dozer then he would be really set. It’s just money 💰😂
Started by EricR on Forestry and Logging
Started by Philbo on Forestry and Logging
Started by Hans1 on Forestry and Logging
Started by treetech on Timber Framing/Log construction
