Stihl MS 261C muffler mod - results
Started by KWood255, March 27, 2021, 09:05:11 AM
0 Members and 4 Guests are viewing this topic.
KWood255
I have a Stihl MS 261C which seemed a struggle as soon as the chain became even slightly dull. When compared to my 365xp Husq, it was lazy unless the chain was perfect. After researching modifications on this site, I opened up the muffler with 3 small louvers, then reset the M-tronic. The performance improvement is incredible. It will now outperform the Husky all day.
Life expectancy of the saw may suffer a bit, but to me its a worthy trade. Ear protection is a must!
axeman2021
Could you take a few pictures to show us just what you did to it.
Joe Perkins
KWood255
I found this method from a different thread on this site a while ago. Results are significant.
PoginyHill
Kubota M7060 & B2401, Metavic log trailer, Cat E70B, Cat D5C, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 462
KWood255
Set the starting/shut-off lever all the way down. Start the saw (as if it were in full choke mode) and leave it idle for 60-90 seconds without touching the throttle. Shut it off, the restart. Done.
Old saw fixer
    The reset for M-Tronic depends on the generation of the system.  M3.0 is the current model and resets with a different procedure than KWood255 describes.  Reset for M3.0 is as follows:  With warmed up saw, apply chain brake set control in cold start and start saw without touching trigger. Allow to idle 30 to 60 seconds then pickup saw,release chain brake and hold trigger wide open until runs normally. You will hear engine revs change until reset is complete, then it runs wide open.  Done.
Stihl FG 2, 036 Pro, 017, HT 132, MS 261 C-M, MSA 140 C-B, MS 462 C-M, MS 201 T C-M, NG 7 Chain breaker/spinner
Echo CS-2511T, CS-3510
Logrite Cant Hook (with log stand), and Hookaroon
KWood255
Dave12
I did that mod on a MS260 that I owned previously.  It really woke that saw up.  I'd reach for it over the 341 or 361 that I owned at the time.  I now have a 261c and I agree with you.  It doesn't seem to have the same grunt that the modded 260 had.  I'm hesitant to mod the muffler on it because it's still under warranty.
Just a small time firewood cutter using a Stihl MS500i, MS400c and MS462c
axeman2021
Sthil has a C261C that does not have the Tronic adjust carb, then they have the C261CM that has the Tronic adjust carb.
The OP posted his was a C261C was this a missed print item?
PoginyHill
Quote from: Old saw fixer on March 27, 2021, 10:49:55 PM
How do you determine which mod a saw is? Mine is about 4 years old. I'm guessing it is not the "current model".
Old saw fixer
     Look at the label on the rear handle, to the extreme right side look at the small print.  If it is M3.0 you will see it printed there.
axeman2021
If you have holes in the saws housing to adjust the carb. it's a CM261C that is a manual carb adjusting saw, if there is no holes to adjust the carb. it's a CM262 C-M that has the Auto Tronic carb adjusting system.
