Author Topic: How do I end the cable?  (Read 1063 times)
Offline Satamax
  • Living in Absurdistan!
« on: March 29, 2021, 12:16:42 AM »
Hi guys.
I was re cabling this old Silvant winch with a friend.
This is cable from a grooming machine winch.  A bit like anti rotation  crane cable.
I am wondering how to finish the end.
Make an eye ?
Crimped ?
With cable clamps ?
Add a hook?
This cable can't be easily spliced to make an eye. IIRC, it has 9 outer strands.
Or
I just crimp a button stop ?
Or a poured button stop? You know when you have those which are conical, you fray the cable in, and pour lead in there.
If crimped, I need to see with the friend who has the tractor. If we can do this on his hydraulic hose machine.
May be not the best solution for me.
I'd rather avoid asking for too many favors.
Another solution?
I need to flog this one. Not loosing too much dough.
Offline mike_belben
  • Pulp Friction
Re: How do I end the cable?
« Reply #1 on: March 29, 2021, 12:20:05 AM »
Are you talking about terminating the end anchored to the drum or the working end?
Psalm 37:16
Offline Satamax
« Reply #2 on: March 29, 2021, 12:22:21 AM »
Working end Mike. The drum end is secured by a plate and a screw.
Offline Satamax
« Reply #3 on: March 29, 2021, 12:24:33 AM »
And i will need to do something about rollers!  ::)
Offline Satamax
« Reply #4 on: March 29, 2021, 12:38:51 AM »
I can do something like this.
http://www.materiel-forestier.fr/pages/fiche.cfm?id=133
On the lathe. And instead of wedges, pour lead in. ( or something along those lines )
Offline Oliver05262
« Reply #5 on: March 29, 2021, 06:53:55 AM »
  The name of that is a spelter socket. It is made with a tapered inner space which is poured with zinc. Lead is very ductile and would not retain the cable under much load.
  It is a strong, but time consuming way to terminate the cable. Be careful to make sure the cable and socket are dry before you pour the zinc, and do not breath the fumes. Best to do this process outdoors.
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
Offline Satamax
« Reply #6 on: March 29, 2021, 07:18:22 AM »
Thanks a lot Oliver.
I didn't know the name. I know about zinc fumes. I'm not sure i could melt it thought. I'm out of oxy acetylene. Covid taking it's toll on my finances.  :'(
That's why i need to sell fast.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: March 29, 2021, 07:39:32 AM »
I think id make a male plug for the socket and hand grind some helical trenches in the plug for the wire to bind.. Then unbraid the end as normal, smash it in there, kink the cable legs outward, weld the male into the female with a few good blobs between the cable tentacles.  Then slice the cables off and hit them with some braze or tacks to bond the cable to the bell.
 I have a choker basket thats made from backbrading cable into itself and terminating the braid in weld dabs.  If the cable isnt galvanaized or too oily you should be able to get some bit of weld on the flushed off tips.. especially if its really compressed from the male and female bullet swedge thingy id make.
Be sure the nose of the bullet mates nicely with the first slide you put on so it doesnt jam or bust it.
Psalm 37:16
Offline Satamax
« Reply #8 on: March 29, 2021, 08:02:09 AM »
Thanks Mike.
I like options.  :)
Offline mike_belben
  • Pulp Friction
« Reply #9 on: March 29, 2021, 08:13:26 AM »
Are you pretty good at threading on the lathe? Internal and external?
Psalm 37:16
Offline Satamax
« Reply #10 on: March 29, 2021, 09:16:43 AM »
Completely useless, i am!
But don't hesitate to tell me.  ;D
Offline mike_belben
  • Pulp Friction
« Reply #11 on: March 29, 2021, 09:33:43 AM »
well i was gonna say if you were decent at internal threading with a boring bar and 60" insert id draw up a reusable 2 piece end lug that could be tightened if it slipped.  if it were me i would try in aluminum first because its just so much easier to thread and fit without breaking lathe tools. id think it'll hold up but if not at least it proofs out the concept in the woods.
Psalm 37:16
Offline snowmountain
« Reply #12 on: March 29, 2021, 11:12:40 AM »
Why not tie a knot on the cable? I was a commercial fisherman most of my life. For years I dredged clams in the ocean. The dredge weighed maybe 2500 pounds empty. The end of the cable would get chafed up every few weeks.  We would just cut it off and tie it around a shackle. I believe it is called a blood knot. Tie the knot around your grab hook, anchor to a tree, then slowly tighten up while whacking with a hammer to tight up. Never had a cable break at the knot.
Jack
Offline mike_belben
  • Pulp Friction
« Reply #13 on: March 29, 2021, 11:14:52 AM »
never a bad idea.  anchor hitch is what i use for cable.
Psalm 37:16
Offline Satamax
« Reply #14 on: March 29, 2021, 11:16:19 AM »
Thanks a lot guys.
Well Jack. I'm affraid the knot wouldn't go well with potential buyers.
Offline mudfarmer
  • Mama Tried
« Reply #15 on: March 29, 2021, 11:44:09 AM »
Thanks a lot guys.
Am I missing something? If you can't do any of these other options and buyers want something clean looking, find 3x cable clamps and a hook for the end. This is how my old Farmi winch came and looking on the internet it looks like others as well. Sounds a lot quicker and easier than doing anything with a lathe or pouring molten metal if the objective is just to get this thing converted to currency in a hurry.
Offline Satamax
« Reply #16 on: March 29, 2021, 12:31:35 PM »
Thanks Mudfarmer.
That's surprising. I see nothing wrong with those for my own, use. But from a commerdial company. That seems a tad "cheap"
Offline mudfarmer
  • Mama Tried
« Reply #17 on: March 29, 2021, 01:15:45 PM »
Thanks Mudfarmer.
Agreed, but it works ;D I bought the winch third hand and very old, had to look up and confirm that others are like this from the factory and it wasn't just one of the previous owners that did this. May not be the case anymore.
Offline John Mc
« Reply #18 on: March 29, 2021, 03:37:27 PM »
What diameter is the cable?
I put this on the end of my winch cable when I replaced it.
You can't see it well in the picture, but there is a wedge inside the body of the blue thing on the left.  The cable enters the narrow end of the body, goes past the wedge, then bends back down over the end of the wedge and into the body, stopping just as the need reaches that narrow end of the body on the left. The cable is snugged down in a bit, and the bolt is placed which holds the chain link/swivel/keyhole assembly. Pulling on the cable just tightens the wedge down against the cable. There is no end prop required on the cable itself (other then cutting off any frayed part so that you have a clean end).
Note that the inch and mm cable sizes listed do not match each other on their advertisement. I'm not sure which is correct. I am using it on a 10mm cable with good results.
You can find it here: Swivel End Fitter - T3 - Hud-son
Offline Satamax
« Reply #19 on: March 29, 2021, 03:55:06 PM »
Thanks a lot John Mc
I had forgotten about this type of sleeve.
I won't buy one. But it gave me ideas.
My cable is either 11 or 11.5 millimeters. I can't remember.
FREE-Accuset (1) display & cable**Cable still available
Started by terrifictimbersllc on For Sale
Last post May 13, 2016, 07:52:24 PM
Cable skidder versus cable dozer
Started by killamplanes on Forestry and Logging
Last post November 15, 2016, 11:24:06 PM
by lynde37avery
moved
MOVED: Cable vs. Grapple/Cable Skidder
Last post November 30, 2005, 09:43:45 PM
by Jeff
question
Started by sticks on Forestry and Logging
Last post December 01, 2005, 05:31:49 PM
by timberjack240
