Author Topic: Introduction and sawmill build  (Read 1026 times)
Offline Rybot
Re: Introduction and sawmill build
« Reply #20 on: April 05, 2021, 11:17:52 PM »
Thanks. I think I will do full enclosure.
 I built mine from sheet metal off the sides of an old cook stove and dryer.
Your engine looks like the HF 420 CC Predator engine? if so what are your thoughts? enough horsepower? That is the engine I am planning on.
Offline Iwawoodwork
« Reply #21 on: April 06, 2021, 12:36:03 AM »
On my mighty mite mill the guards are all metal and as a newbie at sawing I have ruined several blades when I inadvertently jerked the saw backward and the blade came off hitting the guards.  After 3-4 of those (slow learner) I lined the guards with rubber belting which has saved me blades several times, however the belting is not very durable but it was free.  I am now thinking plywood with UHMV  lining would be preferable and save some blades $$$$$ during the learning process.
Offline JoshNZ
« Reply #22 on: April 06, 2021, 04:06:27 AM »
I made mine out of aluminium sheet and have had blade come off twice, no damage either times maybe a tooth missing but maybe it was already, I haven't thrown any out since I got the mill running yet!
Offline ktm250rider
« Reply #23 on: April 06, 2021, 07:54:28 AM »
I built mine with spare metal plate and plywood covers before I even ran the saw.  It was probably one of the first things finished.  I did do a test run without them and the blade came off at full speed.  If it didn't hit a stack of firewood I had, I think it would still be rolling.  Definitely something you want contained.
Offline Rybot
« Reply #24 on: April 06, 2021, 08:15:39 AM »
Making some design progress. Haven't started on the guard yet but I think I have the bandwheel beam complete. I decided to go with 6x2x.188 rect. tubing since several other components will be made of the same and I will likely have plenty left over to do the beam.
I still have to figure out engine mounting. I really want to mount the engine similar to the woodmizer lx 25 where the drive belt goes between the blade and the bandwheel (belt pulley). Thoughts?
Offline trimguy
« Reply #25 on: April 06, 2021, 12:43:25 PM »
Yes that is the 420 CC predator engine. Im happy with it. Never had any problems. Hp wise, I would have to slow down some in wide cuts. It was manual so you could feel as you were pushing it. Ive since upgraded to an Lt40 with a 26 hp and still had times I wished it was larger. Bigger is better. Good luck.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #26 on: April 06, 2021, 05:01:51 PM »
Rybot, that looks nice do your best to balance the head. put your drive pulley where the engine balances the weight so the head does not have any bind. I am very curious to know how the linear bearings are goig to hold up. I was going to use them but after using them for my router sled in my shop the bearings started getting packed with sawdust. Not sure how long term they will work in that application.
I had the 20mm round ones. They do not have the best seal on them. The rectangles should work much better.
Offline Rybot
« Reply #27 on: April 06, 2021, 08:12:08 PM »
I will keep you posted how they work. Like I mentioned in a previous post, Matt Cremona uses them and doesn't seem to have any issues. They are supposed to handle torsional loads very well according to the literature I have read. I am using two carriages on each side to better handle the torsion of any imbalance.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #28 on: April 06, 2021, 08:30:05 PM »
yes. they definitely do all of that. Ebay has good deals on them. but unfortunately they are chinese. But then again even the name brand ones are chinese.
Only reason I have not ordered a set of square ones is because my CNC project got put on hold. But I can see that getting resurrected this summer. Unless I build sawmill v25 instead :)
Offline JoshNZ
« Reply #29 on: April 06, 2021, 11:26:39 PM »
Fwiw crusarius I used them on my vertical lift, and only one on each side, not even a pair, and they're going great. I'd use a pair each side next time though. Cheap bugger I was.
I got them from a friend who has a business producing plasma cutters and he uses them on his machines. He had one of his earlier models in a shop next door and does a bit of profile cutting, he said it hadn't been greased for 10 years just sent back and forth in the crap, no trouble with them.
I reckon they're a solid choice.
Offline Rybot
« Reply #30 on: April 13, 2021, 01:00:33 PM »
Well...I didn't like how the design was going so I decided to start over. I broke one of the first rules of design...that is, start with a design intent.
In my last design I kept changing my mind on things as I was designing things and it made the design process very difficult.
Now that I have a clear design intent things are moving along much more smoothly.
Design intent:
  • Must cut wood (my 3 yo. son's input)
  • Trailer mounted
  • Bed frame made from rect. tubing
  • Bed rails of angle iron
  • Bed length 16' w/ option to add extensions later
  • 48" max log
  • Linear rails for saw head vertical travel and blade guide travel
  • Sawhead built exclusively (or as close as possible) from laser cut flat stock
  • Pushbutton electric throttle control and water/coolant control
  • All manual (for now)
  • Raised "blade bunks" (kind of like the woodmizer lx 150 so sawdust doesn't build up) for fork access
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #31 on: April 13, 2021, 03:11:19 PM »
make the tongue removable. you will not regret it. also make sure you can easily square the backstops to the bed. that is my biggest hate of my mill.
It is also nice to have all the backstops connected together to go up and down the same time. Make the first one taller than the rest that way if the blade clears 1 it will clear them all. Or put a blade stop on it so you cannot cut the backstop.
Offline Rybot
« Reply #32 on: April 13, 2021, 03:38:47 PM »
For this go round I am just doing all manual independent backstops. I will definitely have a blade guard to prevent cutting metal :)
Online thecfarm
« Reply #33 on: April 14, 2021, 07:34:48 AM »
Looks like your log stops go straight up and down?, like mine.
I put marks on mine, at 4-6-8 inches. 4 inches is really 3 inches. So when I set the log stop at 4 inches, I know I have a  inch to spare. Really helps out cutting flitches.
introduction and pics of my slabber build
Started by DaveM on Sawmills and Milling
Last post April 26, 2017, 12:46:03 PM
by DaveM
First sawmill build
Started by BraschBrothers on Sawmills and Milling
Last post January 29, 2017, 01:14:15 PM
by Joe Hillmann
Sawmill build
Started by joegeds on Sawmills and Milling
Last post February 18, 2016, 10:34:33 AM
by york
New Guy with my Sawmill Build
Started by Jimmysmill13 on Sawmills and Milling
Last post November 14, 2018, 09:03:01 PM
by charles mann
