Author Topic: Band sawmill debarker attachment  (Read 430 times)
Offline Thedemoguy
« on: April 03, 2021, 12:27:30 PM »
I知 sure this has been a subject in the past but I知 new to this page and milling in general,.
Has anyone designed a universal debarker that I could adapt to my Hudson HFE30. ?
On the first log I ever put on my new mill, about half way through the log I hit a little tiny rock in the bark. 🤷‍♂️
I would like to eliminate that problem and I致e been thinking about designing a 12v debarker.
I know if I知 thinking about it someone else has already and probably came up with a good design already.
It would need to be 12volt and run off a battery.
Probably spring loaded to ride the log.
Any ideas ?
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Band sawmill debarker attachment
« Reply #1 on: April 03, 2021, 02:06:45 PM »
I thought about finding an old battery powered circular saw and making an arm to mount it with. Ziptie the switch on and have a switch to turn it on and off. Run it straight off the battery.
In my scary mind that would be the best bang for the buck. I am sure you can find some old 12 or 18 volt cordless stuff with dead batteries. 18 volt should still run good enough on 12 volt to not worry about changing voltages. but when all else vails you can just get a simple dc to dc converter.
Offline Thedemoguy
« Reply #2 on: April 03, 2021, 08:53:14 PM »
It痴 hard to believe someone doesn稚 make a universal 12v debarker
Online barbender
« Reply #3 on: April 03, 2021, 09:37:42 PM »
I don't see how you would make a "universal" one, companies seem to have enough trouble engineering them to work on one specific model. I guess you could maybe make a basic system with a different mount for each model of mill.
Offline JRWoodchuck
« Reply #4 on: April 03, 2021, 11:29:50 PM »
Somebody built one that was on this website that was modeled after woodmizers and it looked like he did a great job. I don't recall who it was though. I would imagine if you searched the forum you could find it.
Home built bandsaw mill still trying find the owners manual!
Offline DDW_OR
« Reply #5 on: April 04, 2021, 12:12:18 AM »
use the search button
click on   Show results as messages
then do the following keyword searches separately
debarker
de-barker
"de barker"
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #6 on: April 04, 2021, 11:03:27 AM »
Also include debarked. Autocorrect you know
Offline farmfromkansas
« Reply #7 on: April 04, 2021, 11:57:34 AM »
Just searched the 3 ways for debarker, and only got this thread.  ???
Offline JRWoodchuck
Offline DDW_OR
« Reply #9 on: April 04, 2021, 08:55:21 PM »
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #10 on: April 04, 2021, 09:32:02 PM »
If you change "this topic" to "all topics" in the top search it works well.
« Reply #11 on: April 05, 2021, 06:52:44 PM »
Log Debarker attachment
Started by JohnSR on Sawmills and Milling
Last post December 02, 2013, 12:13:37 AM
by ST Ranch
question
Wood Mizer Debarker Attachment
Started by Nose_Full_of_Dust on Sawmills and Milling
Last post June 04, 2004, 12:53:00 PM
by beerguy
question
S&W Band Sawmill
Started by CValdez on Sawmills and Milling
Last post January 25, 2011, 11:16:34 AM
by CValdez
Looking for Band Sawmill
Started by jemmy on Wanted
Last post March 21, 2020, 12:17:06 AM
by jemmy
