Author Topic: Sawmill Foundation Questions  (Read 221 times)
Offline EBIC
« on: April 03, 2021, 08:35:42 PM »
Hi all,
I have seen a few other posts talking about this but would love some more advise.
I am currently waiting for my sawmill to show up in the mail and am trying to plan out what I can in the mean time.
Where I am feeling particularly confused is around the base/foundation the sawmill should sit on.
I have a gravel driveway in front of my barn. Can it go right on top of that? Would filled cement blocks be better?
Thanks in advance!
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Sawmill Foundation Questions
« Reply #1 on: April 03, 2021, 08:42:01 PM »
   Welcome to the FF. For a much better answer I'd include what kind of sawmill you are buying and where you are located and what you plan to saw. The more details you provide the better the quality answer you are likely to get.
Offline EBIC
« Reply #2 on: April 03, 2021, 08:49:34 PM »
Thanks!
The mill is a Woodland Mills HM122. I will be mostly sawing pine and maple with others randomly added in.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • THEE Forestry Forum
« Reply #3 on: April 03, 2021, 08:54:52 PM »
My sawmill to show up in the mail.
 I just had to type it and say it. :)
Offline Southside
    • White Oak Meadows
« Reply #4 on: April 03, 2021, 09:04:33 PM »
First thought was "Oh no, not the Post Office, it will never arrive"! :D
White Oak Meadows
Offline EBIC
« Reply #5 on: April 03, 2021, 09:15:50 PM »
Well it does sort of feel that way :D
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #6 on: April 03, 2021, 10:43:14 PM »
I made mine from a frame of treated wood packed full of ground asphalt. It sits on 4x6 cross members attached to the wooden frame. It works fine..  If I did it again I would pour a raised concrete  pad  and get the mill a little higher up easier on the body.
Barn foundation questions
Started by deb36 on The Wisconsin Barn Preservation Program
Last post July 17, 2013, 06:08:38 PM
by Cord
Post-To-Foundation Questions
Started by FrankLad on Timber Framing/Log construction
Last post October 03, 2005, 07:07:56 PM
by Jim_Rogers
Sawmill Questions
Started by wascator on Sawmills and Milling
Last post September 18, 2012, 08:46:06 PM
by Okrafarmer
Sawmill questions
Started by CustomWood on Sawmills and Milling
Last post July 15, 2016, 05:08:05 PM
by Ianab
