What kind of steppers are you using?
How are you coupling the engine to the drive? I assume being from a generator the crankshaft is tapered.
Also, did you put a carb on the motor? Assuming it was run on propane in a genset?
Nice solide build... i've got the very same 32 hp generac motor on my ongoing build and am curious how you Mcgivered the shaft.... @sawguy21 if i remember correctly you mentioned to me that those motors were not made to have a side load and would eventually blow the bearing and motor casing apart and was very grateful for that tip,.. so i added a coupler and jackshaft for my pulley.
Quote from: sawguy21 on April 06, 2021, 02:26:09 PMHow are you coupling the engine to the drive? I assume being from a generator the crankshaft is tapered.I ended up machining a taper into the centrifugal clutch/drive pulley.
Quote from: marty3d on April 07, 2021, 11:45:50 PMQuote from: sawguy21 on April 06, 2021, 02:26:09 PMHow are you coupling the engine to the drive? I assume being from a generator the crankshaft is tapered.I ended up machining a taper into the centrifugal clutch/drive pulley. I once had a Chinese diesel generator that the generator side blew up but the little single cylinder diesel was still going strong. I "milled" the tapered shaft to accept a pulley. By milled I mean I started the engine and ran my angle grinder back and forth on the shaft until I got it relatively even and slightly oversized. Then I used a flat bastard file to get it to size, then sandpaper to finish it off. I did it all on the back of my pickup, it actually worked out pretty well.
Started by scottmtfarm on Sawmills and Milling
Started by samdland on Sawmills and Milling
Started by barbender on Chainsaws
Started by POSTON WIDEHEAD on General Board
