Author Topic: To the left, or to the right  (Read 539 times)
Offline lazyflee
  • \m/
« on: April 07, 2021, 06:05:57 PM »
I go right mostly, feels a bit safer since I'm sorta turned that way. Never really thought about it before, but I was cutting today and it popped into my head which way i like better.
Offline thecfarm
Re: To the left, or to the right
« Reply #1 on: April 07, 2021, 07:00:57 PM »
I really don't know. Depends on what side of the tree I am on.
Offline Tacotodd
  • To learn and help
« Reply #2 on: April 08, 2021, 05:16:08 AM »
I’d guess it depends on what you’re referring to.
Trying harder everyday.
Offline hedgerow
« Reply #3 on: April 08, 2021, 10:21:55 AM »
Its funny you should bring this up. I have two guys that help me process my 15-20 cord of wood a year and two of us are right handed and we mostly cut to the right and one is left handed and I see him mostly cutting to the left. I bought this up to them over the winter and neither one notice which way they normally cut. Since I run the Bobcat a lot feeding them logs I notice things like this.
Offline Tacotodd
  • To learn and help
« Reply #4 on: April 08, 2021, 02:23:22 PM »
I just saw the voting part. I go from left to right, so as to take full advantage of the bar for a measuring tape of sorts. That way I’m getting my cuts as close to consistent as possible. But now that I think about it, it’s just as easy going r to l. These are for 16” chunks BTW.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #5 on: April 08, 2021, 04:00:44 PM »
Path of least resistance.
Offline thriceor
« Reply #6 on: April 08, 2021, 10:31:03 PM »
Usually to the left.  I am left handed in most of my endeavors, but not all.  An interesting survey, especially when taking into account predominant side.
...I'd rather trust a man who works with his hands,
He looks at you once, you know he understands...
Genesis- "The Chamber of 32 Doors"
Offline jmur1
  • Wood is King
« Reply #7 on: April 08, 2021, 10:41:35 PM »
My right hand is on the trigger and my (writing hand) left is on the handle.  Prefer cuts to the right.  But could do either if had to.  If I switch hands on the trigger it feels wrong!
Easy does it
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #8 on: April 11, 2021, 07:12:35 AM »
When the log is on the ground it's usually among obstacles like trees and rocks and brush and other logs. Just as Corley says, I take the path of least resistance, often moving from one side of the log to the other and that would change from cutting from the right to cutting from the left or the other way around.
Offline Big_eddy
  • Cutting and Spliiting my way through life
« Reply #9 on: April 14, 2021, 10:01:50 PM »
When  I am cutting logs from a pile, I roll them out onto stringers until I have about 10 logs laid out 12"-18" apart.
Then I stand between the first and second log, facing outward, at one end. Start the saw, cut, left, cut, left, cut, left, cut ...  until I hit the end. Step backwards over log 2 (between 2 and 3) roll it forward until it's up against the blocks just cut , then cut, step right ... to the end.
One step back - roll the log a bit forward, cut, left, cut, left ........... Basically a big back and forth zig zag pattern until all 10 logs are blocks.
Shut off the saw and I have ~100 blocks to pick up and split. If the logs average 12" in dia, that's a bit more than a cord of wood in blocks.
Clean those up and roll out the next 10 logs.
The first left or right depends on which way the wind is blowing (really)
I locate the splitter so the exhaust is downwind of the operator - so sometimes it is on one side of the stringer row, sometimes the other. Every time I finish cutting a group, I put the saw down by the splitter, safely out of the way of the next batch of rolling logs. So the first cut is always on the splitter end - which varies depending on the wind
Left Hand Remington, Left Hand HS Precision / McMillan Stock
Started by Warren on Wanted
Last post February 26, 2011, 09:11:48 PM
by Warren
Looking to the left and there's a new box!
Started by biziedizie on General Board
Last post May 23, 2003, 09:32:48 PM
by chet
How many left???
Started by Woodhauler on Forestry and Logging
Last post March 17, 2016, 10:26:43 PM
by lopet
Not much left...
Started by jd540b on Forestry and Logging
Last post February 07, 2013, 04:50:31 AM
by Green Acres
