98 LT40 Super, power feed not working.
Started by LeeB, April 11, 2021, 07:06:17 PM
LeeB
While jigging back after a cut the mill did not want to stop after switching back to neutral and now will not power feed at all. Breaker is not tripped. Solenoid's are engaging. Haven't checked the power feed control panel yet. Anyone else had this issue?
LeeB
Checked the power feed control module LED's. Getting power to the module. No overload or overcurrent lights. The in and out lights show good. Not reading any power to the feed motor.
WV Sawmiller
   One of the first things I would check would be the power feed belt. Check the tension and that it is not broken. While you are at it might as well do a quick check on the chain and watch the sprockets as they ride on it to be sure everything seems to be engaging properly. Kind of a chicken soup suggestion - can't hurt and might help. Good luck. Let us know what you find.
You have a power feed solenoid that is accessed behind the front and left side panels and it's a tight squeeze.  It's been several years since I replaced mine and tech support led me to it.
LeeB
Quote from: Magicman on April 11, 2021, 08:15:10 PMYou have a power feed solenoid that is accessed behind the front and left side panels and it's a tight squeeze
Seems strange that both would fail at the same time.
barbender
Hmm...it's odd it didn't want to kick out. I guess a quick check at the drive motor for power, and also at the solenoid would be in order.
LeeB
No power at the drive motor. Will check the sols tomorrow.
Quote from: LeeB on April 11, 2021, 10:53:28 PMSeems strange that both would fail at the same time.
both what?  I was only suggesting that it could be the smaller power feed solenoid. ??
LeeB
Problem solved. After doing what I could on my own, I called WM and went through some more tests without success except to find that it was not in the control system. I checked the brushes, which were like new. Good voltage to the motor. As I was taking off the fan cover to be able to check the brush connections I did however find one of the terminals was loose on the motor. Tightened it up and now good to go. Never got the fan cover off before I felt the negative terminal move under my hand.
??  In Reply #1 and Reply #6 you stated "no power at the motor".  ??
slider
mine did the almost same thing .it was the jam nut on the stud coming out of the drive motor. Not the top nut that holds the cable on but the one under neath the cable end .just gently snug them up. Custom sawyer taught me that trick.
al glenn
LeeB
Quote from: Magicman on April 12, 2021, 02:20:57 PMIn Reply #1 and Reply #6 you stated "no power at the motor".
In reply #6 I did state no power to the motor but I was checking it wrong.
customsawyer
When I tighten those studs, I lock two nuts together on the stud and then tighten the nut holding the stud. The locked nuts give you something to hold onto so the stud doesn't turn. If the stud does turn bad things happen. Don't ask how I know.
www.thecustomsawyer.com
LeeB
Quote from: customsawyer on April 13, 2021, 06:58:46 AM
Good advice.
WV Sawmiller
   Be careful - I overtightened the studs on my debarker motor and evidently affected the location of the brushes inside. I found by wiggling/slightly rotating the stud contact would be made and powered the debarker. I had to replace the motor.
