Author Topic: Can someone verify This isnít a Pacific Yew?  (Read 479 times)
Offline JoshTheGentlema
« on: April 28, 2021, 08:37:17 PM »
Iím feel like I know how to tell the difference between a fir and a pacific yew but I have to cut some fir saplings and am afraid Iím gonna mistake a yew. Can someone confirm these are firís and if you have any concrete differences that would be great. This is in the Sierra Nevadaís in California.
Offline aigheadish
  • Tiiiiimmbeeerrr!
Re: Can someone verify This isnít a Pacific Yew?
« Reply #1 on: April 29, 2021, 10:46:28 AM »
I'm a know-nothing amateur but I thought firs typically look like trees and yew usually look more shrub-y.
After doing a search on both, the yew pictures I'm seeing look significantly larger than I realized, but still like a bush or shrub, just really big. Fir looks like it tends to look like a tree.
New Holland LB75b, Husqvarna 455 Rancher, Husqvarna GTH52XLS, Hammerhead 250, Honda VTX1300 for now and probably for sale (let me know if you are interested!)
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #2 on: April 29, 2021, 11:13:56 AM »
Not a Pacific Yew at all. Yew has short pointy needles, grows irregular, with generally smooth reddish bark, although I have seen variations on the bark.  A fir fir shir!  Perhaps Grand or Shasta Red
Offline ljohnsaw
« Reply #3 on: April 29, 2021, 03:03:23 PM »
Looking in my Pacific Coast Tree Finder, I follow this trail through the guide:
Branches/twigs have smooth, round scars where old needles have falling off, then it is a FIR
If the base of the needles is a skinny stalk AND round tips, then it is a White Fir
If no round scars, needles are flat (cannot twirl between thumb and forefinger)
And if the needles are pointed tips and the top of the needle has a ridge, then it is Pacific Yew.
If the needle has everything above but a groove instead of a ridge, then it is a redwood.
Hope that helps.
John Sawicky
« Reply #4 on: April 29, 2021, 08:34:48 PM »
Thanks so much for the help everyone. This helped out so much. I have to clear Fir and Cedar seedlings in a grove of giant sequoias and pacific yews. Wanted to make sure I donít make a mistake on the little ones. I was able to verify all this today on a side by side comparison and donít think I would mistake them now.
Online SwampDonkey
  • Large Tooth
Re: Can someone verify This isn’t a Pacific Yew?
« Reply #5 on: April 30, 2021, 05:01:41 AM »
Yew of any size has this color in the bark ██████ and darker toward purple. You have a fir there. Used to find some 4" sized ones in logging slash on the BC coast. I have some Canada yew on my land, but it just grows knee high and spreads around like running club moss. Bark never gets any color to it.
ďNo amount of belief makes something a fact.Ē James Randi
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: April 30, 2021, 07:12:28 AM »
If yew are from the Deep South (y'all), yew ususally don't know yew.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline BradMarks
    • Pacforest Supply
« Reply #7 on: April 30, 2021, 04:37:23 PM »
Now we're talkin'
Please verify species
Started by doctorb on Tree, Plant and Wood I.D.
Last post June 15, 2018, 08:27:53 AM
by WDH
How do you verify the band set?
Started by kelLOGg on Sawmills and Milling
Last post November 20, 2012, 06:07:53 PM
by John Bartley
verify soffit tenon location and size
Started by windfall on Timber Framing/Log construction
Last post August 20, 2017, 12:43:19 PM
by windfall
How do I verify / change my email info submitted when I registered?
Started by Jasperfield on General Board
Last post August 20, 2008, 10:08:04 PM
by Jasperfield
