Author Topic: Log Master LM-4  (Read 477 times)
Offline threehorse
Log Master LM-4
« on: May 03, 2021, 07:58:45 PM »
Wondering if anyone can help me locate manuals and parts books for an older LM-4. I especially need a wiring diagram . I'm just an old farmer/sawyer who doesn't know enough to pass buy a " as is " piece of machinery and so now I could use some help . I believe this could be quite a substantial mill and would like to fix it right . I will be more than happy to make it worth your while if you have knowledge or info on this mill . Can't find a serial # , overall length of mill is 40 ft and believe can saw 30 - 32 ft log . Has Cat/Perkins diesel engine . Be more than grateful if you can help .  Thanks
Offline tacks Y
Re: Log Master LM-4
« Reply #1 on: May 31, 2021, 07:49:58 AM »
I had the LM3 and not much was in the manual. Did you try calling LM? Is this belt drive? You may want to put this question up on saw mills and milling section. Some do not travel down here often to the wanted area, me included.
Offline tacks Y
Re: Log Master LM-4
« Reply #2 on: May 31, 2021, 07:59:04 AM »
You may want to search LM 5 on here. I saw a post from MS Tireman that said he was getting a manual for the 4 (he has a 5)
Log Master LM3
Started by tacks Y on For Sale
Last post May 21, 2020, 08:09:47 PM
by Two Trax
log master lm4
Started by cherish on Sawmills and Milling
Last post June 14, 2014, 12:51:02 AM
by 5quarter
Log Master LM-4
Started by threehorse on Sawmills and Milling
Last post June 28, 2021, 10:55:40 PM
by MSTireman
Got my new Log-Master LM2!!
Started by 379hammerdown on Sawmills and Milling
Last post June 29, 2012, 06:58:40 AM
by slider
